1970 442 over flow position with washer bottle and canister on passenger side
Old Apr 18, 2018 | 07:52 AM
huskalade's Avatar
What’s up Oldsmobile friends!
I am installing an radiator overflow. I need to know correct way to install with washer bottle and smog canister all in same area. I bought overflow from the Parts Place it came with bracket and spacer. The directions do not have washer bottle and canister in it. I am trying to build factory correct car. I know I can do without canister and I know I can move washer bottle but that would knot be correct. When I follow directions everything seems to be bunched up. I’ve seen the overflow positioned sideways also but do not have brackets. Can anyone please help with pictures or advice ? Thanks in advance!
Old Apr 18, 2018 | 04:18 PM
Yellowstatue's Avatar
Well, '70 did not have an over flow bottle, but the bottle you have is '71 or '72 and will fit '68 to '72. Where you have it placed is the correct spot.
Old Apr 18, 2018 | 04:40 PM
RetroRanger's Avatar
72 Olds CS
But. If the 71-72 had the overflow doesn't the washer tank go on the other side ? So if it was a dealer installed option on a 70 wouldn't the same hold true ? IDK I'm just asking as it does look busy over there
Old Apr 18, 2018 | 04:42 PM
tru-blue 442's Avatar
Old School Olds
I didn't think the e-vac canister came into play until the 71 year model. Am I wrong
or was that a California thing?
Old Apr 18, 2018 | 04:43 PM
There's a lot of room there. Look under the hood of an Aurora.
Old Apr 18, 2018 | 05:31 PM
VC455's Avatar
Barely Registered
!970 cars delivered to California had the vapor emission canister.
huskalade
Oct 26, 2019 02:53 PM
Toocool
Feb 15, 2018 12:34 PM
71POWER
Oct 6, 2012 08:29 AM
1971 442 convert
Aug 22, 2012 07:50 PM
slowolds
Hurst/Olds
Jun 15, 2010 05:09 PM
