1968 / 1969 speedometer differences?
Old Mar 23, 2020 | 07:17 PM
v8al's Avatar
Registered Olds Owner
Curious if the differences on these two speedometers are based on the different model years 68/69 or if it's just a part supplier difference?
Notice the dots versus lines under the numbers.
Old Mar 23, 2020 | 09:18 PM
2blu442's Avatar
It sounds like you missed the reply on the other thread. In 1968 the speedometer cable housing screwed onto the back of the gauge. In 1969 it had a spring steel clip that would fit over a lip on the speedometer cable housing. Post a picture of the backs and we can tell you what year(s) you have. John
Old Mar 23, 2020 | 09:26 PM
v8al's Avatar
Thanks, I did see that post before the other thread went away. While I get that you can positively ID based on how the speedometer attaches to the back I just wanted to know if you could tell visually from the front.
Old Mar 23, 2020 | 09:28 PM
2blu442's Avatar
OK, one of the 1968 or 1969 guru's will have to help with that. I'm sure someone here knows!
Old Mar 23, 2020 | 10:38 PM
I always thought that they were the same, so I went out to the garage and checked my '69, it's like the one on the right in your pic, with the exception of the auto trans gear indicators. Mine is a 4 speed, so it does not have anything on the bottom.
Old Mar 24, 2020 | 12:21 AM
hurst68olds's Avatar
here are most of the variations, dash ('68s) VS. dot ('69s)
1968s
Old Mar 24, 2020 | 12:23 AM
1969s
Old Mar 24, 2020 | 02:38 PM
matt68F-85's Avatar
Thank you for posting those pictures. I always thought they were the same.
Old Mar 24, 2020 | 03:16 PM
v8al's Avatar
Agreed! Thanks for posting! There are quite a few differences between the two years.
Old Mar 24, 2020 | 06:03 PM
I seem to remember reading about the high beam indicator being a different color depending on year? My 69 is red, maybe the later cars have blue indicator lenses?
Old May 20, 2021 | 04:14 PM
v8al's Avatar
1970 had a red high beam indicator
1971 & 72 had the blue high beam indicator.
BeenThere
Dec 28, 2018 12:22 PM
Elephant_Engine_Ernie
Dec 22, 2015 06:15 AM
dnmfranco
Aug 2, 2013 02:22 PM
marko68
Jun 5, 2011 07:12 AM
jdana24
Apr 13, 2010 09:18 AM
