1967 400 with the .921 lifters
Old September 5th, 2012 | 12:10 PM
franks1967Olds442's Avatar
Do you know the length of the stock pushrod ?
Old September 5th, 2012 | 12:15 PM
Oldsmaniac's Avatar
Why do you ask? If machine work or gaskets have been done the stock ones may work but will not be optimal for performance.
Old September 6th, 2012 | 07:12 AM
pushrod lengh
I bought all new parts for the motor and never thought to compare them to the old parts. started putting the motor together and went to put the lifters in and found that they were to small, then i replaced them with the right ones and never thought to check the pushrods. now to me it seems like the valves are staying open a little and the motor not running right. so now i am thinking that the pushrods are to long.
Old September 6th, 2012 | 10:19 AM
Oldsmaniac's Avatar
For this to actually happen the pushrods would be excessively long. The hydraulic lifters have a good amount "play". If you did not save the old pushrods then I would suggest you verify that the valves fully closing. You could loosen a rocker when valves are supposed to be closed and see how much tension is on the spring or if valve stem moves. Dont guess and just swap parts on a hunch. This can get expensive.
Old September 6th, 2012 | 05:06 PM
Oldsmaniac's Avatar
When I assembled my 67 400 I ended up using 9.5 inch pushrods. With these I shimmed the rocker bridges I think .090 and it gave me the lifter preload I wanted. Just enough to keep rockers quiet. You should be in the ballpark using similar pushrod length.
Old September 9th, 2012 | 09:03 PM
Oldmofogo's Avatar
re
It doesnt matter what you are working on, the correct way to obtain pushrod length is to measure and be sure!
shamusj
March 21st, 2023 03:12 PM
bluecab
September 14th, 2021 08:52 AM
66-3X2 442
July 1st, 2015 08:38 PM
L69
December 2nd, 2011 11:27 PM
geckonz08
May 21st, 2010 08:29 PM
