1966 Oldsmobile A/C
Old Apr 11, 2020 | 03:39 PM
bw1339's Avatar
1966 Oldsmobile A/C
Hello,
I've been working to revive the A/C in my '66 Toronado. I rebuilt the A6 compressor, had the hoses remade, replaced all o-rings, dryer, flushed the system, added 10 oz of PAG oil150 and 30oz of R152a (manual called for 4 lbs of R12, so 60% of that).
I had tested the POA with compressed air and set it to 30 PSI. With the system running, it still read 30 PSI. High side was 80 PSI. The hose coming out of the evaporator was cool, but after the POA, it became very cold, to the point that frost was forming on it. Outlet air temperature was probably in the 50s (60deg day).
Any suggestions?
Thanks.
Old Apr 11, 2020 | 04:07 PM
Charlie Jones's Avatar
Phantom Phixer
The POA is clogged or restricted .
Did you pull a good vacuum of 30 inches or more for at least two hours , before charging ?
Also the POA may need a different setting for R-152 .
You might try consulting with Original air group ;
https://www.originalair.com/FitmentC.../FitmentSearch
Old Apr 11, 2020 | 04:09 PM
bw1339's Avatar
It held a vacuum for 1/2 hour before I charged it.
That the POA seems to be acting as an expansion valve would seem to confirm that it's restricting flow, but would a clogged POA still be able to regulate pressure?
Thanks.
Old Apr 11, 2020 | 04:19 PM
You are 8 ounces short on refrigerant based on the information you posted.
Old Apr 11, 2020 | 04:23 PM
Phantom Phixer
Thanks.
No , it acts like an expansion valve .
Re-build or replace the POA . Making sure it is adjusted to R-152 standards , if that is what you are using .
Old Apr 11, 2020 | 05:18 PM
bw1339's Avatar
I have another POA valve. I'll switch it tomorrow. Thanks.
Old Apr 14, 2020 | 09:59 AM
Don R.'s Avatar
Question - what is R-152?
Old Apr 14, 2020 | 10:15 AM
bw1339's Avatar
It's an industrial refrigerant that is commonly used in keyboard duster sprays. It's supposed to have very similar properties to R12 and work very well in unmodified R12 systems. And it's dirt cheap.
The Flash
Ninety-Eight
Mar 8, 2016 06:50 PM
PalmSpringsOlds
Jul 17, 2012 09:22 AM
oldsF85Fan
May 12, 2011 08:17 AM
Joffroi
Jul 30, 2010 10:42 AM
rustycarr
Feb 27, 2007 06:52 PM
