1966 cutlass a/c weight? removal?
Old Feb 27, 2007 | 03:31 PM
rustycarr's Avatar
Ive got a 66 cutlass with air that doesnt work and was thinking of installing aftermarket air. how hard is this and how much weight would i be removing? all underdash,firewall,condensor,evap,etc. thanks.
Old Feb 27, 2007 | 06:24 PM
2blu442's Avatar
I'm not sure which aftermarket air system you planned to use, but it seems to me that it would be simpler to just repair the factory system. You could have it flushed and converted to the new coolant. If the compressor is bad, you could purchase a used or rebuilt one. I'm not an expert with AC but unless you've got a hole in something there's not a lot of things to go bad beyond the compressor. I guess the dryer should be replaced as it could be contaminated. Anybody else out there with experience doing their AC system?
Old Feb 27, 2007 | 06:52 PM
rustycarr's Avatar
probably right, vintage air makes a universal kit, and it cleans up the engine compartment(my main reason) but if it just needs something small i ll go that route.
InTheCutt
May 29, 2013 09:27 AM
Mikes65
Sep 4, 2012 06:14 PM
pcard
Suspension & Handling
Dec 24, 2011 09:29 AM
Vega
Oct 4, 2011 12:30 PM
Aceshigh
Sep 8, 2011 09:31 AM
