1955 olds gas pedal gets stuck ?
Old Mar 8, 2021 | 11:24 AM
Shot Gun Rich's Avatar
Gas pedal gets stuck driving sometimes . What would be causing this the transmission or the linkage ?
Old Mar 8, 2021 | 11:55 AM
Could be any one of a litany of things. Broken motor mount. Worn carb throttle shaft bushings. Worn or broken linkage or brackets. Interference from something out of place in the engine compartment (I had this happen to me). Floor mats (ask Toyota about that!).
Old Mar 8, 2021 | 12:48 PM
ignachuck's Avatar
Frank Ignachuck
In addition to all the above ^^^^ there's a four letter word that solved the sticking brake pedal on my '56 last year- LUBE.
Old Mar 8, 2021 | 01:58 PM
Pfft. Ask idiots about it. I double up floor mats on my Tacoma, no issue. Although a dealer did chop my pedal and I just about threw the service manager through a window, then made him locate an NOS original and install it. Of course, I got a clutch, so no big deal.
Old Mar 8, 2021 | 02:01 PM
Yeah, I figured I'd pull your chain a little with that...
Old Mar 8, 2021 | 08:36 PM
Ok thank you, I spray the engine compartment carburetor linkage with pb blaster once in a while, So thinking maybe when it wears out the linkage gets stuck.will check the carb throttle shaft bushing.
Old Mar 8, 2021 | 08:48 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Lube the back side of the pedal where it slides on the linkage.
Old Mar 8, 2021 | 10:15 PM
Yes thank you will do that too, thank u so much
Old Mar 14, 2021 | 08:51 AM
Tedd Thompson's Avatar
Or start at the peddle and remove one piece at a time till you find he drag spot and fix it. Most importantly you don't want anything related to throttle control or brake control to rune your day..... Tedd
oldsmobilejim
Aug 31, 2020 07:44 PM
brandon reynolds
May 22, 2020 02:38 PM
R8der4life
Jun 4, 2013 06:51 PM
vista cruiser 1
Sep 2, 2012 04:50 PM
vista cruiser 1
Sep 2, 2012 03:39 PM
