Fuel gauge
Old Apr 22, 2015 | 09:47 PM
olds$$6565's Avatar
Fuel gauge
65 cutlass fuel gauge will not read past 1/3rd of tank. New sending unit?????
Old Apr 22, 2015 | 11:57 PM
Which way past? Higher or lower?
Old Apr 23, 2015 | 06:20 AM
Remove the wire that goes to the sending unit from the gauge and with the key on see if it goes past full, then ground the wire and see it goes to E. If it does then the problem is with the sender.
Old Apr 23, 2015 | 12:58 PM
olds$$6565's Avatar
No offense MDchanic but 1/3 is just over 1/4 of tank as if float is partially sunk
Old Apr 23, 2015 | 01:05 PM
So it won't read higher than ⅓.
The gauge reads Full when there is little to no continuity (broken sender wire or ground), and Empty when there is essentially no resistance between the gauge and ground.
Therefore, you cannot have a bad connection or a broken wire, and it is unlikely that you have a short.
That leaves a problem with the sender (or maybe the gauge) as the most likely problem.
See this thread for more information.
Old May 2, 2015 | 06:19 PM
olds$$6565's Avatar
Fuel gauge
Old May 2, 2015 | 06:38 PM
olds$$6565's Avatar
fuel gauge
Having trouble with fuel gauge disconnected beige wire gauge goes to full , grounded beige wire gauge goes to empty 2 new sending units..... Frustrated
Old May 2, 2015 | 06:50 PM
I know it's frustrating, and I'm sorry I don't have any specific help for you, but we only need one thread on the subject.
That being said, and given what was discussed in the other thread, it sounds like the problem is with the gauge itself.
Old May 2, 2015 | 06:54 PM
olds$$6565's Avatar
What are the steps to getting new fuel gauge? HELP
Old May 2, 2015 | 08:56 PM
I merged your threads. Your problem is with the fuel sender, your test with grounding the wire and leaving it disconnected proves that everything from the sender forward is working properly. Either you are getting bad senders or its not internally getting a ground through the tank.
Old May 2, 2015 | 09:28 PM
olds$$6565's Avatar
JPMDaddy
Jan 31, 2020 04:01 AM
trez
Mar 23, 2011 12:20 PM
ozzyolds
Aug 13, 2008 11:11 AM
69-Sguy
May 1, 2008 08:43 AM
ride
Sep 1, 2006 07:07 AM
