air conditioning
Thanks for the reply
I just wanted to make sure the car I am looking for has one. I am looking for from early to mid 80's
On the adds I am looking at I am not seeing anything reference saying anything about the air conditioner.
Can you see my other post for another question. I just want to know how easy is it to fix.
For the most part is it as easy as replacing the compressor?
People not alive in the 1960s may find this hard to believe, but A/C was a pretty rare option in those years. In 1966, probably only 50% of all cars got A/C, and since that number skewed higher on the luxury cars, lower-end cars like the Cutlass typically were a lower percentage. If the ad doesn't say A/C, the car probably didn't come with it. If not, there are a lot of aftermarket retrofit options available.
If the car does have A/C, repair likely means a new compressor, new O-rings, and a rebuilt suction throttling valve. Personally, I'd install one of the conversion kits that adapts the STV system to a Compressor Cycling system like newer cars. This also entails an R-134 conversion. Few shops today will know how to properly work on an older A/C system like that.
