455 blocks stamping not casting
Old Mar 23, 2015 | 05:38 PM
edzolz's Avatar
I have two 455 blocks and the small pad where the numbers are stamped are confusing me. One has 30M123456. The 3 would mean Olds and the 0 would mean 70, correct? What does the M mean? The other has 30X123456. Same question, what does the X designate? The M block came out of a 70 442 Pace Car, the other came from ?
Old Mar 23, 2015 | 07:03 PM
don71's Avatar
same but different
X is the Kansas City engine plant. My 1970 350 has the X.
Old Mar 23, 2015 | 07:17 PM
oldstata's Avatar
Justin
M = Lansing
The remainder numbers are the last of the vin from the car witch it was in
Old Mar 23, 2015 | 08:44 PM
Nope, sorry. By federal law, the VIN derivative MUST match the VIN of the car that the engine was installed in at the factory. The "X" represents the Fairfax, KS assembly plant. The Fairfax plant only built full size cars, so any engine with an "X" for the assembly plant was originally installed in a full size Olds.
Old Mar 25, 2015 | 08:47 PM
edzolz's Avatar
The 30M block came out of a 70 442 Pace Car Convert. So Lansing would be correct for this block.
Old Mar 27, 2015 | 06:50 AM
442much's Avatar
The M123456 on the engine should match the last part of the VIN. If it does it's the engine that was originally installed in the car.
BackInTheGame
Jan 6, 2015 04:57 PM
Nickyloves442s
Oct 15, 2012 11:55 AM
wagonmaker
Jul 30, 2011 03:13 PM
coltsneckbob
Drivetrain/Differentials
Aug 8, 2009 09:02 PM
blunce
Sep 10, 2007 10:17 AM
