Horn Cap
Hello, I noticed that the center horn cap on my 72 cutlass supreme is cracked. it is the sport steering wheel, 4 spoke. can this cap be popped out from underneath the rubber circle to be replaced ??
If you are talking about the clear center piece with the rocket emblem inside it, yes. Gently work it out with a small screwdriver. Replace it the same way. Now, getting just the center part will be the big problem, but I've done this to convert a Buick center into an Olds center.
The best way is to drill out the three rivets (carefully) and the cap comes apart easily. Watch eBay for the centers----new ones are usually about $50.00, but I have seen auctions for new ones that ended around $40.00. There are two styles--the differences are so minute that only a finicky judge would know.
I changed a Buick center one time to a 68 Cutlass center for a friend so he could put a three spoke Buick wheel on his Cutlass. Looked great. Just popped out the 68 Cutlass center with a small screwdriver like Joe said.
Oldssupreme
Feb 20, 2013 09:59 AM
Oldssupreme
Jan 24, 2013 07:36 PM
