Horn Cap
Old Jan 8, 2015 | 12:24 PM
Apollo's Avatar
Question center cap
Hello, I noticed that the center horn cap on my 72 cutlass supreme is cracked. it is the sport steering wheel, 4 spoke. can this cap be popped out from underneath the rubber circle to be replaced ??
Old Jan 8, 2015 | 12:34 PM
Apollo's Avatar
Horn Cap
Hello,
The center horn cap on my 72 cutlass is cracked. It is the sport steering wheel 4 spoke. Can this plastic cap be popped out from underneath the rubber seal and easily replaced ???
Old Jan 8, 2015 | 02:11 PM
Originally Posted by Apollo
Hello,
If you are talking about the clear center piece with the rocket emblem inside it, yes. Gently work it out with a small screwdriver. Replace it the same way. Now, getting just the center part will be the big problem, but I've done this to convert a Buick center into an Olds center.
Old Jan 8, 2015 | 02:14 PM
RetroRanger's Avatar
72 Olds CS
I made a center for an old sport wheel i had by cutting a round flat piece of plastic out and sticking an SSI ctr cap emblem on. looks better than a crack but not as good as a nice sport wheel cap
Old Jan 8, 2015 | 02:15 PM
Tacking your question onto the end of an unrelated thread is probably not the best way to get an answer (nor is asking the same question in multiple forums) so I merged it into this identical thread.
Old Jan 8, 2015 | 02:39 PM
Apollo's Avatar
Sorry, I'm new to this forum. I can get a replacement from FUSIK. Thank you Joe !!
Old Jan 8, 2015 | 03:06 PM
lemoldsnut's Avatar
I agree with Joe finding just the center is a trick. But do as he says and also if you take it and put it in a cup of hot water it will be more pliable to work with.
Old Jan 8, 2015 | 03:33 PM
Dave Siltman's Avatar
The best way is to drill out the three rivets (carefully) and the cap comes apart easily. Watch eBay for the centers----new ones are usually about $50.00, but I have seen auctions for new ones that ended around $40.00. There are two styles--the differences are so minute that only a finicky judge would know.
Old Jan 8, 2015 | 03:59 PM
I've never had to do that.
Old Jan 9, 2015 | 06:12 AM
edzolz's Avatar
I changed a Buick center one time to a 68 Cutlass center for a friend so he could put a three spoke Buick wheel on his Cutlass. Looked great. Just popped out the 68 Cutlass center with a small screwdriver like Joe said.
Oldssupreme
Jan 24, 2013 07:36 PM
dz442
Nov 24, 2012 11:04 AM
OldsManNJ
Jul 31, 2012 10:14 PM
Jeff70442
Apr 21, 2012 03:21 PM
