How do U Unlock a Theftlock stereo?
Old Sep 18, 2008 | 03:29 PM
I just replaced the theftlock stereo in my 98 regency with another from the boneyard. (cheaper to replace than fix - cd was screwed up). Anyway, the radio went in great, but it is locked. GM says this will happen anytime the battery is disconnected. Never happened like that on my old stereo, so I think they're slinging some horse hockey.
1. How do you get the unlock program and code WITHOUT going through GM? I called them and asked them but they insist they need my car for the whole day because it takes about 2 hours. Excuse me, I'm so allergic to crap from them lately. I know that you press some buttons on the radio to get the codes and then have to dial [FONT='Verdana','sans-serif']1 800 537 5140 and give them a code to identify whether it's chebby, olds, buick etc[/font]. Once they get this 6 digit code they will give you the 4 digit unlock for your stereo. Now I need your help. What buttons do I press and what are the 6 digit codes for Oldsmobile and saturn?
2. While I was out and about I also got my wife a AM/FM stereo CD c/w built in equalizer for her 1996 Saturn. (25 bucks - not bad) Duh,,, same theftlock problem. That's why I need the 6 digit code for Saturn. Thanks guys, I know someone out there has the answer to this issue.
Old Sep 18, 2008 | 04:43 PM
Bluevista's Avatar
Registered
My wife's car had that system and if the power went out you had to have the individual code for that specific radio to activate it. But I think there was another way like you said though.
Allan
Old Sep 18, 2008 | 07:00 PM
elcaminodave's Avatar
Try this website. I have not tried it myself to know for sure that it works.
http://www.autoforumz.com/modules.ph...nlock-GM-radio
If it does not work and you get the codes off the radio like the post says, I may can help you tomorrow.
Old Sep 19, 2008 | 05:36 AM
Wow! I have never heard of that before. Seems like something GM would do though. If all else fails you could get a Best Buy CD player and install it yourself. Of course, that would be more expensive than a slavage yard replacement.
Old Sep 19, 2008 | 06:13 AM
d2_willys's Avatar
917
Old Sep 19, 2008 | 10:04 AM
Ok, I'll give that a try. Thanks for the link.
Old Sep 19, 2008 | 10:11 AM
gearheads78's Avatar
car guy
Each radio has its own code but a lot of people never lock it. Once it is locked only way I know is to get a GM dealer to unlock it without the codes that the last person put in it.
Old Sep 19, 2008 | 10:34 AM
Neither of these radios is RDS so that helps. From info I've been able to gather, there's 2 kinds of programing. One is where the radio has a default code that is matched to the cars engine computer If that's the case you have to go to GM to get it unlocked. Seems like that was typical of Corvette and some high end models.
The second default is the actual code the radio will have installed from the factory and is the automatic default if the power goes out or something. Anyway I'm not a radio expert so I hope this isn't causing confusion. I'm assuming that this would be the actual code the radio was built with and overrides anything that is programmed in afterwords, if that makes any sense.
Apparently, most people DON'T change their theftlock code, and GM doesn't recommend it either. Guess it's kind of like reprogramming your TV remote, and I hate the idea of doing that cause it never works right afterwards.
I've heard that GM will unlock it for free if they sold you this problem. But, they didn't and I don't want to pay GM. I found a website that sells GM unlock codes guaranteed to work for about 5 bucks. Pretty reasonable. What I think is that they're just passing along information that's out there for free making $5.00 a shot in the process.
There's way too many cars out there with theft deterent for someone not to know how the unlock works. I just don't trust GM Service anymore after the last 2 times I got screwed by them.
Old Sep 19, 2008 | 10:47 AM
car guy
Dealer usually charges .5 hours for the service so if you can get the codes for $5.00 jump on it.
Old Sep 19, 2008 | 11:29 AM
If you get the codes off the radio like the link I sent you says, I think I can get the unlock code for you. Just let me know.
mojonitro
May 3, 2012 08:40 AM
mauls
Jul 15, 2011 07:25 AM
44TEETWO
Dec 7, 2010 07:33 AM
krissiibabii
Aug 29, 2010 06:35 PM
