455 oil pan
Old Jun 5, 2014 | 07:25 PM
crank shaft's Avatar
455 oil pan
Can anybody tell me if a 350 oil pan is the same as a 455? Are they the same for a 1970 cutlass?
Mike
Old Jun 6, 2014 | 05:51 AM
Smitty275's Avatar
Engine Builder
Basically they are the same. 455 pans had a "ledge" in them that extended over the sump. They will interchange.
Old Jun 6, 2014 | 06:12 AM
What was the ledge used for?
Old Jun 6, 2014 | 06:21 AM
Smitty275's Avatar
Engine Builder
Can only surmise it was an attempt at windage control.
Old Jun 6, 2014 | 06:24 AM
Ok, thank you so much for the info!
Old Jun 6, 2014 | 07:18 AM
They will interchange, but they are not the same. BBO oil pans have a pair of "bump-outs" (for lack of a better term) at the front of the sump where it joins the main pan. I can only surmise that these were to allow oil to flow back to the sump more easily past the larger counterbalance weights and crank throws on the BBO crank.
SBO pan:
BBO pan:
Old Jun 6, 2014 | 06:53 PM
Thanks Joe, I just ordered the correct one from fusic today, You saved my butt again! I owe ya another one! Mike
Redog
Oct 20, 2015 03:29 PM
defiant1
Aug 12, 2014 04:43 PM
captn442
Jun 22, 2009 07:42 PM
mdd71
Jan 9, 2009 03:56 AM
