anyone else seen an oil pan like this?
bought a 394 and it has this growth on the oil pan. dont know why. looks like a 1qt sump but why would anyone put this on could this be somethin special? other 394 does not have this. also here is numbers on head.thumb drive bob 119.jpg
thumb drive bob 107.jpg numbers look like 065548. any clue?
This "can" added about 1/2 quart oil capacity,without changing the depth or the design of the pan.
It also probably helped cool the oil better.
"Back in the day' I remember neophyte mechanics putting an oil filter wrench on this thing and trying to remove it to change the oil filter.
Attachment 89475 numbers look like 065548. any clue?
The numbers started at 001001 so this is the 64,548th engine made that year.
Just before the number should be a prefix letter either an H or J . H= 2 barrel, J= 4 barrel. the engines were painted either red or green. Red was high compression (10.25 to 1) green was low compression (8.75 to 1). There may have been a suffix letter also, none= hi compression, E or L = low compression, S= Starfire.
Your engine would decode to a 2 barrel, high compression engine.
looks like a Gor a 3 ahead of the bolt 065548 after. supposed to be a 61 skyrocket engine. but i never believe sellers. stickers and paint are easy. green 2 bbl motors become red 4bbl motors in about an hour. bought motor and tranny for 350 so i figure i did fair. runs decent compression was very low at first like 45psi left it run in three to five minute bursts over three weeks as to not overheat ( no water) comp rose to 135 respectfully. figure i will install and run on highway and if it dont get to 180 then i will tear it down next winter. right now spendin the dough on the body.( pa car)
I didn't know we were talking about a 61 engine. Info changes.
Prefix letter; F= low compression, G= hi compression,
Suffix letter; none = 4 barrel, H= 88 hi comp option, E= export.
Seller was right 1961 4 barrel 10 to 1 compression. (Skyrocket)
droptopron
April 15th, 2012 04:50 AM
56rocket
November 30th, 2010 06:23 PM
