1972 cutlass brake swap
No, there is no easy swap using later model spindles.
Julian:
I'd like $250 plus the ride (as they say). The rotors look like they still have some like left in them (you can still see the wear groove). I removed one of the calipers to make sure they weren't frozen up and it moved smooth enough to remove the pads; but you should definitely plan on rebuilding the calipers with new seals and pads and have the rotors turned down for straightness. I decided to install 12" C4 vette brakes on my project which is why I'd like to sell these. I would use white vinegar followed by Evapo-rust to clean them up.
Julian:
Baer Brakes for $300
Julian:
I don't mean to sound like a smart a**, where can you get a big brake kit for $300 and What size are the rotors? I've been piecing together a 12" front kit using C4 vette parts because the kits are expensive or lack good engineering.
rida142
Sep 12, 2010 07:37 PM
