1969 h/o
Old Mar 27, 2014 | 08:09 PM
springbryan's Avatar
RelaxinOldsGuy
1969 h/o
I finally have the H/O in my shop and up on stands. I pulled the back wheels off and they still have the push lock keepers on the drums. I believe it stills has original brake pads, just a bit of info. My question is this car is so original what do I do to fix things trans leak? Just pan I believe can I use after market rubber gasket same with differential. whats the right thing to do. I will have more questions tomorrow when I spend more time under it .
Old Mar 28, 2014 | 03:33 AM
tru-blue 442's Avatar
Old School Olds
Brian, there a few places that can leak
besides the pan gasket.
Front or rear seals, trans shifter output
shaft has a small seal and also the oil fill
tube has an O-ring to seal at the trans too.
Also there is another O-ring at the speedo
gear housing that can weep or leak also.
Do you know where the rear is leaking?
Those pinion shaft seals can be a pain.
Old Mar 28, 2014 | 05:32 AM
pogo69's Avatar
morgan
if you can get nos stuff use that. if not, your at the mercy of some of the crap made in china. just dont buy the cheap rebuild stuff. i dont know off hand of any specific tranny or rearend gasket/seal kits, someone will know though
Old Mar 28, 2014 | 06:05 PM
RelaxinOldsGuy
The trans pan is the first leak I need to fix and see what else might also be leaking. it is the differential cover. This a true 98% original car can you tell me what type of gaskets would have been used on these 2 items. Or if it matters when having it judged
Old Mar 29, 2014 | 06:50 AM
pogo69's Avatar
morgan
you will be all set with a cork and paper/fiber gasket...dont think it would matter for judging
crystal59
Dec 13, 2024 06:38 PM
Gearhead442
Feb 2, 2020 11:56 AM
mcutlass1969
Drivetrain/Differentials
Feb 12, 2008 08:59 AM
