1969 h/o
1969 h/o
I finally have the H/O in my shop and up on stands. I pulled the back wheels off and they still have the push lock keepers on the drums. I believe it stills has original brake pads, just a bit of info. My question is this car is so original what do I do to fix things trans leak? Just pan I believe can I use after market rubber gasket same with differential. whats the right thing to do. I will have more questions tomorrow when I spend more time under it .
Brian, there a few places that can leak
besides the pan gasket.
Front or rear seals, trans shifter output
shaft has a small seal and also the oil fill
tube has an O-ring to seal at the trans too.
Also there is another O-ring at the speedo
gear housing that can weep or leak also.
Do you know where the rear is leaking?
Those pinion shaft seals can be a pain.
The trans pan is the first leak I need to fix and see what else might also be leaking. it is the differential cover. This a true 98% original car can you tell me what type of gaskets would have been used on these 2 items. Or if it matters when having it judged
crystal59
Dec 13, 2024 06:38 PM
mcutlass1969
Drivetrain/Differentials
Feb 12, 2008 08:59 AM
