Hurst His & Her Shifter
Old Nov 28, 2013 | 03:15 PM
Olds442redberet's Avatar
I recently picked up a Hurst his and her shifter. I was lucky enough to have found it on Craigslist in North Carolina where I have friends. So I was able to make a deal over the phone and my friend picked it up and paid for it for me. Unfortunately, my buddy failed to secure the console in the bed of the truck and it flew out the rear as he drove down the highway. Fortunately, the shifter and the console top panels were inside the cab of the truck. So the loss is minimum.
But without the original console I don't have a template to use a guide for modifying the console inside my 442.
1. I need instructions on how to cut my console so the shifter fits. I think I see a guideline on the inside of the console.
2. Will my stock floor shift cable hook up to the Hurst shifter, or do I need to find a specific cable for this application?
3. Where can I find the specific Hurst handle to mount to the top of this Hurst shifter?
Old Nov 28, 2013 | 03:17 PM
oldsmobiledave's Avatar
Curious
Curious.....has your "friend" recovered from the beating yet?
Old Nov 28, 2013 | 03:49 PM
The instructions are in your Chassis Service Manual, and yes the molded-in guide line is where you cut it.
Old Nov 28, 2013 | 07:42 PM
dfire25's Avatar
"Trying to fix her right"
X2, Its actually pretty easy, I've done it a couple times.
You do need a different shifter cable for a dual gate shifter, its shorter?
The 70-72 Hurst shifters use a black ball on top of the shifter handle, not a "T" handle.
Old Nov 28, 2013 | 08:19 PM
Any ideas on where to get the black ball shifter handle and the cable?
Are there any lessons learned that I should keep in mind before starting to modify my console?
Old Nov 28, 2013 | 08:27 PM
dfire25's Avatar
The Parts Place is probably the cheapest for the ball and cable.
I used a dermel type tool with a cutting disc to cut the console. Actually it was the rotary tool from Harbor Fright Tools.
http://www.harborfreight.com/variabl...kit-68696.html
http://www.harborfreight.com/1-1-2-h...ack-34749.html
Old Nov 28, 2013 | 08:32 PM
dfire25's Avatar
Also, cut from the under side as much as you can so if your tool skips you don't run the risk of messing up the show side. Oh and wear safety glasses!
Old Nov 29, 2013 | 04:51 AM
Easy enough! I have a dremel tool with cutting blades.
The Parts Place! Cool! I was worried that I'd be hunting for parts for awhile in order to finish this project.
Old Nov 29, 2013 | 06:31 AM
I just bought the shifter cable from the Parts Place via Ebay, and a somewhat expensive shifter ball from another Ebay seller. When everything comes in I'll get it all installed in the convertible and let everyone know how it turned out.
The Turbo 400 is heading to the shop today as well.
Thanks for the help
Old Nov 29, 2013 | 07:06 AM
dfire25's Avatar
There are a couple threads here on where to mount the shifter to the floor as well. Make sure you do a search for them.
Old Nov 29, 2013 | 04:11 PM
Thanks for the insight.
Is the wiring harness for the His/Hers shifter the same as with the common floor mounted auto shifter?
Old Nov 29, 2013 | 04:26 PM
Transmission rebuild
I just took the Turbo 400 over to an old fellow's shop here locally. It's in his garage. Turned out to be a really knowledgeable old timer with decades of experience under his belt. He's going to build it to handle 550 plus horse power, which is what I am expecting to get from a Harden Marine motor I am planning on installing into the 442. Anyway, I just wanted to share my day's adventure. I attached a picture of his humble, but really cool shop and one of his old Olds.
Old Nov 29, 2013 | 05:17 PM
dfire25's Avatar
Yes
Old Nov 29, 2013 | 05:19 PM
don71's Avatar
same but different
Cool photos, that's a pretty big mic he has on the work bench.
Really like the color on the old Olds. I wonder what paint(code) that is?
The wiring should be the same, not sure. There should be a light for the console and one for the shift indicator.
My dual gate has part numbers on the lighting harness as such;
4431 HA
4432 HB
This wiring is plug in play, the console harness simply plugs into the accessory lighting or what ever its called.
Old Nov 29, 2013 | 05:51 PM
Paladin31's Avatar
Olds442redberet...humble shop..maybe, but the organization & cleanliness speak volumes on an old school professional. Good call using him, and I love his Olds. Best
Old Nov 30, 2013 | 05:35 AM
4431 HA
4432 HB
The mic is actually a large vise designed to hold Turbo Hydromatics. The mechanic can mount the transmission in the vise, after which he can rotate it around as needed as he works on the transmission. Malcolm apparently picked this tool up from General Motors many years back. His garage is full of cool old tools. His workshop is a working museum.
Old Apr 8, 2014 | 05:30 PM
Where can I get the little plastic bushing for the dual gate? There are actually two little plastic pieces I need in order to complete the restoration of my shifter.
Old Apr 8, 2014 | 06:04 PM
jensenracing77's Avatar
Are you talking about the center where it goes into the front and back hole? If so, I think only one end gets it. Not sure where to get them.
Old Apr 8, 2014 | 06:14 PM
Yes, I need one of those and I also need the plastic bumper the shifter slides against on top. It is maybe a quarter inch by an inch and a half
Old Jul 4, 2014 | 02:57 PM
I finished cleaning up a Hurst Dual Gate shifter. I media blasted most of the parts, used steel wool on the parts I didn't want to etch, and I replaced a few of the shiny parts that I thought should be replaced.
I have three of these now. I was thinking about cleaning them all up before selling them, but man parts are expensive.
fast67vellen2o
Jun 9, 2012 03:31 PM
magwa
Aug 6, 2011 01:41 PM
70 cutlass s
Jun 30, 2011 04:01 PM
442much
Jan 31, 2011 04:11 AM
tim72
Apr 1, 2009 08:14 PM
