Crappy Fuel
Crappy Fuel
I changed the fuel filter in my neighbors car yesterday and let all the fuel spill out into this metal bowl. Took a look at it, not only was it dirty, it was loaded with water too. Could not believe how much was in the filter. No wonder his car was hesitating. Told him to put some dry gas in the tank. Took a picture, not sure how good it came out but you can kind of see how dirty everything was.
If it does any damage the gas station is also responsible. They are supposed to check their tanks with measuring stick, if there is more than so many inches of water in there they need to stop selling fuel and correct it.
What kind of tank or car was this and how much is it driven? A steel tank will produce a lot of water through condensation as it sits. I have a boat with a 86 gal tank. Unbelievable how much water this tank will produce over a winter if you do not fill it all the way up
Not driven very often. Low original mileage. Will have to check the tank tomorrow to see what it is made of. Out of a early 90's Furd Mustang.
That is a bummer.
At least you were able to help your friend.
Undoubtedley water in gasoline isn't good for a car; however, it's my understanding that a diesel engine can be down right destroyed by water in the fuel. Is this correct?
halfmoontrail
Feb 22, 2013 12:14 PM
