66 442 vacuum trunk release
Old Aug 18, 2013 | 05:23 PM
bobfo1's Avatar
I've got a vacuum trunk lock release that I will install on my 66 442, but I do not have the "shaft" that connects the vacuum motor to the lock mechanism. I am going to make one using the standard "shaft", but I need to know the length of the "shaft". Can anyone give me the length of this piece.
Old Aug 18, 2013 | 05:30 PM
It's going to be more difficult than that. You need a shaft that has the spring loaded joint in it. I've got mine around here somewhere, or back home. The lock cylinder has a shaft, then there's the joint, then it goes through the latch, then into the vacuum actuator. The lock cylinder will turn both pieces of the shaft, but the vacuum actuator only turns the part going from it to the latch to the joint, and not past that to the lock cylinder.
bobfo1
Oct 20, 2014 01:48 PM
rcktdoc
Apr 22, 2014 04:12 AM
Chuck_66
Jan 11, 2012 02:03 AM
ros6872
Mar 7, 2010 06:12 PM
KQQLCAT
Oct 20, 2008 07:21 AM
