Reviews for Ram Air Restoration exhaust manifolds.
Old Mar 21, 2013 | 06:48 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
Can anyone offer any feedback on this product? I'm thinking about using them on the 70 toro 455 I'll be putting in my car.
Ram Air Restoration oversize factory exhaust manifolds.
http://www.ramairrestoration.com/old...y-headers.html
thanks
Old Mar 21, 2013 | 07:27 PM
66-3X2 442's Avatar
thanks
Hey Walter,how you doin,get over that little bump in the road? I sure hope so.
Mike
Old Mar 22, 2013 | 03:09 PM
Hi Mike,
Thanks for asking. Yes,getting better,over the bump but still on a gravel road.The good news,I think I can see paved smooth road in the distance.
Walter
Old Mar 22, 2013 | 08:18 PM
66-3X2 442's Avatar
Hi Mike,
Walter
That's sounds great,good luck.
Mike
Old Mar 23, 2013 | 07:17 AM
stevengerard's Avatar
do you have the original manifolds? What else are you doing to the engine? Will the extra size matter enough for the extra price?
Old Mar 23, 2013 | 11:19 AM
The original manifolds are Toro manifolds and will not work with an A body.
My short term goal is to install the stock 70 toro engine and save some money for a rebuild. When it comes time for a rebuild I want to keep compression at the point of requiring 93 octane.Add a little more cam,some mild head work to improve flow,a higher stall convertor to match the cam,compression and 3.42 posi.
The car now has 2.5 inch dual exhaust.
The car will receive a factory OAI.
Another goal is to keep things looking very close to factory so headers are out of the question.
thanks
Old Mar 23, 2013 | 12:17 PM
ok, If that's the case I probably have an original set of manifolds that I would let go for less than the repos - just need to find them.
Old Mar 23, 2013 | 06:27 PM
dc2x4drvr's Avatar
A few years ago, I was considering these manifolds, I think they were claiming a 25% increase in flow..check to make sure the outlet will handle 2 1/2 " headpipes.
Old Mar 23, 2013 | 06:51 PM
Thank you for the offer.
The main reason I was considering these is because of the increased airflow.
Old Mar 23, 2013 | 06:54 PM
Yes,the link I provided is for the oversize manifolds. They accept a 2.5 inch head pipe and they say that provides an 18% increase in airflow.
Their standard manifold accepts a 2.25 inch head pipe.
Bernhard
Apr 27, 2013 10:54 PM
1967bigdaddy
May 19, 2011 04:17 PM
billykissell
Apr 6, 2011 02:45 PM
wjustinmartin
Jun 26, 2010 05:33 PM
Jon Dahl
Feb 28, 2009 08:58 AM
