HEI Distributor
Old May 10, 2012 | 12:52 PM
rcrac3r's Avatar
HEI Distributor
This has probably been asked about already. My 72 Cutlass w/350 has the original points distributor. i would like to upgrade that to an HEI distributor. Will a distributor from a Chev engine work or does it have to be from an Oldsmobile? If so which years of distributor are the same?
Old May 10, 2012 | 01:06 PM
72CUTTY's Avatar
I'm pretty sure it wont work! I had to buy an MSD one specially for Oldsmobile
Old May 10, 2012 | 01:20 PM
TripDeuces's Avatar
It will not work, you need an Olds distributor. HEI started in 74 so any of them with a 4 pin ignition module will work.
Old May 10, 2012 | 01:29 PM
Tony72Cutlass'S''s Avatar
Olds distributors rotate counter clockwise
Chevrolet rotates clockwise.
You ABSOLUTELY need an olds distributor. And besides, who wants a chevy distributor in their olds anyway!
It'd be like putting a mopar air cleaner on a Toronado....
Old May 10, 2012 | 01:41 PM
rcrac3r's Avatar
So a distributor out of a 78 Toronado should work? I have a line on a parts car.
Old May 10, 2012 | 03:09 PM
BILL DEMMER's Avatar
Just the facts...
chevy and olds dizzy's are physically quite different, the olds being shorter and fatter on the part that goes into the block, chevy being thinner and longer. olds uses a hex shaft to drive the oil pump off the dizzy, chevy uses a flat blade that is tapered thicker the further you go up the shaft.
yes, the '78 dizzy will at least fit your motor, the timing curve will need to be re-curved for your specific application. the vacuum advance will probably be too early and too steep for your motor, you'll want a different one, maybe an adjustable. unfortunately, all of the adjustable vacuum cans i've seen allow only for adjustment of total vacuum advance-not the point at which advance starts or the rate vs. vacuum. then, you need to make sure you have a 4-pin module inside, as stated above. make sure there are only 3 wires going from the cap to the body of the dizzy, and no other wires coming out of the base.
bill
Old May 10, 2012 | 04:12 PM
rockettruck's Avatar
'78 Toronado HEI...
My old '78 Toronado XS had an HEI distributor, but it was controlled by an early version of an ECM called MISAR if I remember right. I think the advance curve was set by this rudimentary computer, but I'm not sure if anything else other than the module made the distributor different.
I'm sure any other '78 Olds HEI would work--perhaps even non-XS '78 Toronados...
Rockettruck...
Old May 10, 2012 | 09:34 PM
Just the facts...
i was reading about the misar system a couple months back. it has additional wires coming from the dizzy body. if the original poster follows what has already been stated with regard to choosing the correct type HEI dizzy, he'll be on the road to a superior ignition system.
bill
joepenoso
Jun 4, 2014 01:56 PM
oldscruiser
Feb 15, 2011 12:44 AM
Oldsmobile Jo
May 30, 2010 07:58 AM
dan2286
Mar 27, 2009 01:20 PM
Frankenpez
Feb 8, 2009 07:38 PM
