455 gaskets
Old Apr 5, 2012 | 05:25 PM
charlierogers's Avatar
455 gaskets
what gaskets are you guys using on the 455ci head, intake w-30 ?
charlie,,,
Old Apr 5, 2012 | 06:08 PM
stevengerard's Avatar
my W30 intake is so thin that I used a really thick felpro intake gasket set. Not sure the number but I can check tomorrow.
Old Apr 6, 2012 | 08:58 AM
thanks let me know.
Old Apr 7, 2012 | 12:45 PM
DeltaPace77's Avatar
I built my 455 up from a bare block, with Dave Smith worked W-30 heads, and Edelbrock Performer intake. Looked up the gaskets used, and here's the list. FelPro FEL-KS2613 master kit, which includes PermaTorque sandwiched steel head gaskets. FelPro FEL-MS96004 Valley pan intake gasket, Mr Gasket MGR-5945 Ultra Seal header gaskets, Mr Gasket MRG-5971 collector gaskets, and Summit SUM-G1490 SS 7/16" shouldered header bolts. Dave Smith recommended a light Peratex copper spray on the head gaskets, so what I did. Used Permatex #2 on all the others, ran a bead of RTV on the front and rear intake surfaces, instead of the rubber end pieces. Also had the rear crank rope seal ridges machined off, and used a Ford 460 two piece neoprene rear main seal. Put this engine together in the 90's, and not a leak or drop of fluids anywhere. The Mr Gasket Ultra Seal header gaskets look pretty standard, but are actually wire mesh cored, and only need to be torqued once.
Old Apr 7, 2012 | 01:21 PM
Mike77's Avatar
I saw on e-bay the two intake manifold rubber gasket that go on the end for a 455.
Very reasonalbe $150.00 WTF!!
But they did have GM stamped on them and NOS! Just what you need 40 year old rubber gaskets, what could go wrong.
manny72supreme
Mar 7, 2015 10:13 AM
scooter123
Apr 21, 2013 09:30 AM
J-(Chicago)
Apr 19, 2008 05:29 PM
dallas6778
Nov 20, 2007 10:04 AM
Deltarocket
Jun 5, 2007 06:54 AM
