455 head gaskets
455 head gaskets
Does anyone have an idea of what Head Gaskets perform well on a 1969 455 "F" Block with "C" Heads? I heard the Felpro Gaskets are .043 and the stock ones were only .017.... Therefore dropping the compression .5 ?
Just got the engine from a 69 toro with 80k on it,
Im pretty new to this and any help will be appreciated.
http://www.summitracing.com/parts/SCE-079152/
Give that a try, should get your compression closer to stock
Agreed, .028" and I am glad I hoarded some of the 55661's several years ago. Since they come in plastic bags and boxes, they should not dry out. I have seen Fel Pro's apparently dry out, and coolant leach through the fiber core if they are old.
Thanks .......... You are correct pressed the one key instead of the two key .027 or .028 is correct ......... my bad!!!
As per POGO69-->Rocket Racing & Performance
Item# 121066854533 .... OLDSMOBILE .028 THICK HEAD GASKET OLDS V8 ROCKET RACING 330 350 400 455
Total: $114.20
Total: $114.20
As per POGO69 - is correct --> Rocket Racing & Performance
Rocket Racing & Performance LLC
rocketracingperformance.com
Item# 121066854533
Total: $114.20
Item# 121066854533
Total: $114.20
Item# 121066854533
Total: $114.20
Item# 121066854533
Total: $114.20
