Spark plug gap
Old Apr 11, 2011 | 12:46 PM
rhaberm's Avatar
Spark plug gap
Installing pro comp hei distributor, what should spark plug gap be?
Bob
Old Apr 11, 2011 | 01:51 PM
svnt442's Avatar
I'd go .045. DON'T get the plugs for HEI as they are set up for an overly wide gap of .080. This was done for emissions and all it did was burn out coils faster.
Old Apr 11, 2011 | 02:14 PM
Bob
I changed my 72 to HEI and kept the plugs at the original gap. There are varying points of view on HEI vs points distributors. The HEI I put in works fine, but I'll probably change it back to points dist so I can install my dual snorkel air cleaner. NOTE: if you put in HEI, the stock 4 bbl air cleaner will not fit any more. It will hit the HEI cover.
Old Apr 12, 2011 | 11:53 AM
71 Cutlass's Avatar
One of None W-31
[quote=svnt442;271089]I'd go .045.quote]
Mine are at .045 using an MSD distributor.
bonesbmx
Jun 2, 2020 02:10 PM
ChrisM
Mar 7, 2009 08:07 PM
boese1978
Mar 16, 2008 03:50 PM
ChrisM
Nov 1, 2007 02:23 PM
66starfire
Jan 3, 2007 10:31 AM
