Spark plug gap
I changed my 72 to HEI and kept the plugs at the original gap. There are varying points of view on HEI vs points distributors. The HEI I put in works fine, but I'll probably change it back to points dist so I can install my dual snorkel air cleaner. NOTE: if you put in HEI, the stock 4 bbl air cleaner will not fit any more. It will hit the HEI cover.
