Can i get the trunk of my 69 cutlass convertable open from the inside without a key?
Old August 17th, 2010, 04:27 PM
krissiibabii's Avatar
I have no keys for it but i can get inside the main part and i can...wiggle my way into the trunk but idk how or even if you can get it open from the inside.
krissiibabii is offline
Old August 17th, 2010, 07:10 PM
The end of the lock cylinder has a small rectangular bar projecting from the end of it. This bar (about 3/16" x 1/2" cross section) passes through the lock mechanism and should be visible from inside the trunk. Grab this bar with a pair of pliers and twist counterclockwise (as seen from inside the trunk) to unlatch the latch.
joe_padavano is offline
Old August 18th, 2010, 09:55 AM
Do you have to lift up then turn or not cuz mine is sticking.
Old August 18th, 2010, 10:00 AM
TK-65's Avatar
On two 65 parts cars I had I crawled in the trunk and unbolted the latch from the deck lid.
TK-65 is offline
Old August 18th, 2010, 10:39 AM
Past Administrator
Oldsguy's Avatar
should be able to turn, then lift up. You will probably have to do what TK suggested if it is sticking.
Oldsguy is offline
Old August 18th, 2010, 10:44 AM
67442nut's Avatar
Ditto, only I've done it on '67's and '69's.
I couldn't fit through the opening in the bulkhead behind the back seat, so, I put together
3 or 4 feet worth of 3/8" extensions (enough to reach the bolts in the catch) with a 7/16" socket.
I reached through and got the socket on the bolts on the catch that way.
67442nut is offline
Old August 18th, 2010, 10:58 AM
Angry
i unbolted the three bolts keeping the trunk to the body but the small piece of metal is still stopping it, what do?
Old August 18th, 2010, 03:07 PM
bil
bil's Avatar
Could it be binding? Maybe have someone lightly push down on the lid while you try to turn the lock lever. ---bil
bil is offline
Old August 18th, 2010, 03:35 PM
442much's Avatar
Who are you planning to kidnap?
442much is offline
Old August 18th, 2010, 05:35 PM
GoodOldsGuyDougie's Avatar
Just remove the back seat and get a extra extra long extension and un do the Bolts-(2) holding the lock mechanism on the inside of the trunk in place.They will fall down in the trunk and the trunk will open. I did it just a while back when my lock broke. Good Luck.
GoodOldsGuyDougie is offline
midrange
June 21st, 2013 02:21 PM
mmurphy77
Site Help
September 12th, 2011 10:32 AM
mscofer
April 4th, 2010 06:35 PM
Flye
May 10th, 2009 08:13 AM
Quick Reply: Can i get the trunk of my 69 cutlass convertable open from the inside without a key?
