internal combustion - how does it work???
Old Jun 11, 2010 | 06:01 AM
jeffreyalman's Avatar
so I am just trying to figure out how just the press of my foot makes it all happen
I know that the gas pedal links to the carb and opens to allow more gas to flow in, and opens primaries and secondaries via mechanical linkage, but what makes the engine go faster?
the simple act of introducing more fuel? does the gas pedal (throttle linkage) connect to the distributor at all?
kind of like a chicken and egg question I guess.
Old Jun 11, 2010 | 06:08 AM
Interesting. I can answer one of your questions.
No. Spark advance is controlled by mechanical advance and vacuum advance in an older car.
Old Jun 11, 2010 | 06:31 AM
Bluevista's Avatar
Registered
My turn...Where do babies come from?
Old Jun 11, 2010 | 06:34 AM
wolfman98's Avatar
Captain of my ship
Storks I hope the Gulf doesn't swallow up too many of them.
Old Jun 11, 2010 | 06:36 AM
extreme1's Avatar
An engine in it's simplest form is an air pump. What happens when you press your foot down is the carburetor allows more air into the engine, more air equals more RPM.
So, when the airflow through the carburetor increases it meters more fuel into the mix, more fuel equals more horsepower.
this is the simplest explanation I can think of, from there we go into explaining how a 4 stroke engine operates, how for every 2 crank revolutions any given cylinder only fires once.
http://auto.howstuffworks.com/engine1.htm this link will give you a more detailed explanation of how the magic on the other side of the throttle cable works.
Old Jun 15, 2010 | 08:02 PM
coltsneckbob's Avatar
As u depress the gas pedal u open up throttle valves in the carburator. That allows more air (and fuel) to flow. This combination creates a more powerful explosion in the cylinders. The more powerful the explosion the more power thus the faster the piston is driven. There is very much (close to) a linear relationship between the amount of air/fuel and piston speed. Which implies a similarly direct relationship to throttle valve position. There are other ancillary things that engage, such as vacuum advance, that also cause engine speed to increase.
Old Jun 16, 2010 | 12:13 AM
thanks for the answers, makes sense now
Old Jun 16, 2010 | 04:07 AM
66ninetyeightls's Avatar
Land Yacht Captain
http://en.wikipedia.org/wiki/Four-stroke_engine
2blu442
Oct 4, 2016 06:57 PM
jamac
Jun 15, 2013 11:50 AM
coltsneckbob
Oct 14, 2010 04:05 PM
henryford
Feb 1, 2010 09:05 PM
NoVa_144
Oct 27, 2009 08:12 AM
