Tire sizes vs speedo
ok so I may have done it - I put 23575R15 on the 88 and the speedo reads approx 3 mph low i.e. reads 60 GPS says 63
pretty much consistent from 30 - 80
did I put too big a tire on?
No, you just need to change the speedo driven gear. Actually, 3MPH off is darn good.
only because it is not erring on the side of caution and I am getting more and more forgetful lately (52) and the last thing I need is to get stopped for speeding when I know better but forgot which (of the 3) cars I am in
you are right 3mph is no big deal unless you are going 74 in a 70 zone accdg to the speedo (not bad) but are really going 77 accdg to the truth (not good)
http://speedometersolutions.com/ http://www.transmissioncenter.net/sp...n_______va.htm here's a couple of places.
Here is the best Tire size calculator I've found on the net. Visually shows you what the differance is.
http://www.miata.net/garage/tirecalc.html
Hmm... I thought the 71-76 B&C bodies were supposed to run 235/75 R15. Isn't that the closest size to the old J 78s that were on it from the factory?
3mph is pretty darn close. I can see the desire to be dead on though.
[quote=Olds64;173739]Hmm... I thought the 71-76 B&C bodies were supposed to run 235/75 R15. Isn't that the closest size to the old J 78s that were on it from the factory?
I think that I have to agree with you, my dad had 235/75 R15's on his '71 98, and I commented that they were the size used on pickups!
I don't know about today, but back 'round 1970 the factory set up every car/trans/rear/tire combination so that the speedometer would read 1 - 2% fast, usually closer to 2%. (unless you ordered the calibrated police speedometer option)
