Tire sizes vs speedo
Old May 2, 2010 | 08:03 AM
jeffreyalman's Avatar
ok so I may have done it - I put 23575R15 on the 88 and the speedo reads approx 3 mph low i.e. reads 60 GPS says 63
pretty much consistent from 30 - 80
did I put too big a tire on?
Old May 2, 2010 | 09:19 AM
Originally Posted by jeffreyalman
ok so I may have done it - I put 23575R15 on the 88 and the speedo reads approx 3 miles per hour low i.e. reads 60 GPS says 63
No, you just need to change the speedo driven gear. Actually, 3MPH off is darn good.
Old May 2, 2010 | 09:29 AM
easy for you to say! where do I get one? what do I ask for? so these tires are a bit too big huh?
same size on Toro and CC and speedos are exact on those
Old May 2, 2010 | 09:41 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Why are you even concerned with a 3mph error? That's plenty close enough for me.
Old May 2, 2010 | 09:44 AM
only because it is not erring on the side of caution and I am getting more and more forgetful lately (52) and the last thing I need is to get stopped for speeding when I know better but forgot which (of the 3) cars I am in
you are right 3mph is no big deal unless you are going 74 in a 70 zone accdg to the speedo (not bad) but are really going 77 accdg to the truth (not good)
Old May 2, 2010 | 10:31 AM
http://speedometersolutions.com/ http://www.transmissioncenter.net/sp...n_______va.htm here's a couple of places.
Old May 2, 2010 | 10:35 AM
awesome thanks! so I guess I will run it by the speedo shop before it goes to bed for the summer thanks a million!
Old May 10, 2010 | 07:38 AM
Natas's Avatar
Here is the best Tire size calculator I've found on the net. Visually shows you what the differance is.
http://www.miata.net/garage/tirecalc.html
Old May 10, 2010 | 07:50 AM
pretty cool I think I went from 225 75R15 to 235 75R15 and accdg to that website
ok, closer
Old May 10, 2010 | 08:49 AM
Hmm... I thought the 71-76 B&C bodies were supposed to run 235/75 R15. Isn't that the closest size to the old J 78s that were on it from the factory?
3mph is pretty darn close. I can see the desire to be dead on though.
Old May 10, 2010 | 08:59 AM
I though the Bs were HRs I will look at the glovebox sticker when I get home and report
Old May 10, 2010 | 10:30 AM
[quote=Olds64;173739]Hmm... I thought the 71-76 B&C bodies were supposed to run 235/75 R15. Isn't that the closest size to the old J 78s that were on it from the factory?
I think that I have to agree with you, my dad had 235/75 R15's on his '71 98, and I commented that they were the size used on pickups!
Old May 10, 2010 | 10:58 AM
Let us know what you find out Jeff. Now I am wondering...
Old May 10, 2010 | 11:05 AM
ok
75 88 Conv = HR15 = 19575R15 right?
if right, then speedo @ 60 = really 65.3 which is more realistic, I am @ 64ish
Old May 10, 2010 | 02:32 PM
BlackGold's Avatar
I don't know about today, but back 'round 1970 the factory set up every car/trans/rear/tire combination so that the speedometer would read 1 - 2% fast, usually closer to 2%. (unless you ordered the calibrated police speedometer option)
Old May 10, 2010 | 07:17 PM
68DeltaCustom's Avatar
ok
The 88's had HR78x15=225R75x15
The 98's had JR78x15=235R75x15
Old May 11, 2010 | 05:41 AM
AHA!
Old May 11, 2010 | 05:47 AM
I am not convinced HRs were 225
I think they were 195 or maybe those were G
So long ago so many brain cells ago
:cheers:
MYBOYDAVE
Wheels and Tires
Dec 26, 2011 04:45 PM
nonhog
Nov 12, 2011 10:21 AM
71KUTLASS
Wheels and Tires
Feb 26, 2011 05:56 AM
Chumley
Feb 19, 2011 11:13 AM
Want-A-Vert
Feb 3, 2007 11:23 AM
