Cylinder walls
Old Feb 28, 2010 | 03:52 PM
rtpassini's Avatar
Cylinder walls
i just took the heads off my 455. The walls feels nice and smooth except for a slight ridge on top. Good sign??
One piston had a little gouge on the top of it. But the pistons are going to be replaced anyways.
Also, anyone know how much a short block weights? (with internals still there)
Old Mar 1, 2010 | 05:44 AM
The ridge is normal. Once your machinist disassembles the engine he can check the block for wear using a dial bore gauge.
Old Mar 1, 2010 | 03:48 PM
rtpassini's Avatar
im hoping that there will be minimal machining involved. anything to keep the price down.
Old Mar 1, 2010 | 04:22 PM
74 Omega's Avatar
From www.oldspower.com
455
Block = 206.5lbs
Crank = 75lbs
Bare "E" Head = 50.5lbs
Cast intake = 60lbs
8 pistons and rods (with rings) = 33lbs
Copper Nine Eight
Wheels and Tires
28
Jun 2, 2015 07:56 PM
Tedd Thompson
Jun 21, 2014 04:41 PM
Tedd Thompson
Care and Appearance
29
Oct 27, 2013 05:34 PM
Freebeer
Wheels and Tires
37
Aug 15, 2012 08:58 PM
martine
Brakes/Hydraulic Systems
Feb 5, 2004 10:28 AM
