head selection
Old Today | 10:38 AM
REO442's Avatar
Thumbs up head selection
Short and sweet. I have a set of Ga heads and a set of C heads. What is my best overall option for the 455 rebuild? Any distinct advantages or pitfalls? Forum gurus, do your magic.
Old Today | 12:51 PM
With the exception of the J heads, all the heads flow similar. The G heads have the advantage of hardened seats, but unless you really plan to work the engine like it owes you money, then stock unhardened seats isn’t that big a deal. Use whichever are in the best condition.
For the best bang for the buck, aftermarket aluminum!
Old Today | 01:07 PM
v8al's Avatar
Registered Olds Owner
Check the spring seats on the two sets of heads. The Ga heads are probably deep spring seats while the C's are probably shallow spring seats. The Ga's probably used valve rotator retainers - hence the deeper spring seats.
Either set of heads come in both big and small valve versions. Both can be converted to big valves if desired.
The valve spring pockets are probably the biggest difference between the two sets of heads.
W30455
Jul 23, 2025 12:26 PM
Bernhard
Jun 10, 2023 04:27 AM
73aussie455
Aug 9, 2019 04:40 PM
jag1886
Nov 9, 2013 09:55 AM
ctrain22
May 27, 2009 10:49 AM
