72 cutlass emblems placement
Old May 28, 2026 | 07:45 PM
mikejana's Avatar
Jet lagged & Hungry
Just getting the 72 Cutlass back together.
Paint went well and I can't find a template for the emblems.
I'm mostly concerned with O-L-D-S-M-O-B-I-L-E letters on the trunk.
Help,advice or criticism is appreciated.
Old May 28, 2026 | 08:07 PM
Do you own the 1972 CSM? Locations, emblems, scripts & decals are listed in the CSM.
Old May 28, 2026 | 08:08 PM
Ooops I may have lied. I think they're in the PIM. I'll look.
Old May 28, 2026 | 08:12 PM
Yeah, they're in the PIM. I think I posted some numbers on a thread several years ago. I'll see if I can dig them up.
Old May 28, 2026 | 08:14 PM
OK, I have a sachet of images I created.....INCOMING!!
Old May 28, 2026 | 08:17 PM
Old May 28, 2026 | 08:18 PM
Old May 28, 2026 | 08:37 PM
Forgot I had these...
RH Side
RH Side
LH Side
LH Side
Old May 28, 2026 | 09:37 PM
mikejana's Avatar
Jet lagged & Hungry
Thank you Chief,
I had your pictures of the Cutlass fender emblems, but never found the others.
I am super grateful, Exactly what I needed.
Old May 28, 2026 | 09:38 PM
Originally Posted by mikejana
Thank you Chief,
Old May 28, 2026 | 10:04 PM
It makes sense that panel piercings are not available. Those were stamping department die designs. Each panel goes from a coil, to a blank, to a panel. The blank goes through the press, and, at a minimum, gets hit twice. The draw die does most of the work, and the second die, I think it is trim, trims the "handles" the first die used. Some stop there, but there are also piercing dies for holes, and flange dies to do weird sideways things. Nowadays, all emblems and text are glued on with 3M double sided wonder tape. They load the emblem in a jig and it datums to the nearest edge and on it goes.
Old May 28, 2026 | 11:19 PM
John - This is a really good bit of history. Thanks for sharing.
Old May 29, 2026 | 06:16 AM
mikejana's Avatar
Jet lagged & Hungry
So blessed and stoked for this information.
Chief, John?, you are a gift to the hobby.
Thank you
Old May 29, 2026 | 08:01 AM
Not even 100% I published those detailed images of my O L D S M O B I L E trunk (compartment) lid to this site. Well, they're up there now.
Trukkface
Sep 26, 2025 05:50 AM
442Fred
Jun 4, 2023 04:20 PM
70cutlass
Nov 1, 2017 01:22 PM
ziff396
May 28, 2012 05:21 PM
beebee78
Apr 2, 2011 05:06 PM
