W30 Aluminum manifold plug correctness
Old Apr 17, 2026 | 11:12 AM
Jungle Cat's Avatar
W30 intake plug correctness.
Does anyone know if this hex head brass plug is correct for a 70 aluminum intake or is the square plug type correct? This is for applications that don’t use the three port gizmo,
Old Apr 17, 2026 | 12:15 PM
jensenracing77's Avatar
All 70 W-30 had the 3 port temp/vacuum valve so that plug has to be wrong.
Edit, I am not aware how the California emissions setup works but I think it uses the 3 port valve also...
Old Apr 17, 2026 | 01:22 PM
dc2x4drvr's Avatar
Use an headless brass or aluminum plug with internal hex.
Old Apr 17, 2026 | 01:24 PM
Jungle Cat's Avatar
In 70 assembly manual the three port switch is conspicuously absent on the w30 engine vacuum page
Old Apr 17, 2026 | 01:25 PM
Jungle Cat's Avatar
Old Apr 17, 2026 | 01:33 PM
VC455's Avatar
Barely Registered
Also in the 1970 PIM:
Near the bottom, right corner look at the four squares at the intersection of parts 103880 and 1230500 with product codes TT and TS (W-30 Auto and SM).
It shows no vacuum switch and a plug in the hole.
Elsewhere in the PIM, the plug shows as having a square head.
Old Apr 17, 2026 | 03:22 PM
tnswt's Avatar
'70 4-Speed W Machine
Here is a picture of what that plug looks like on my 4-speed car. Hope this helps.
Old Apr 17, 2026 | 03:50 PM
Jungle Cat's Avatar
Good Picture thanks, this diagram shows square plug. It’s vague on usage
Old Apr 17, 2026 | 04:40 PM
Jungle Cat's Avatar
Now I see you have a 4 speed I hope you don’t mind a couple of questions. Under hood of car I just bought is a mess, I’ve done a few Olds but this is first 4 speed. Are the plastic straps that hold the positive battery cable to the valve cover white of black? I see both. It looks like one attaches to the air cleaner spring clip? Where does second one go? Are there only 2?
Old Apr 17, 2026 | 06:03 PM
tnswt's Avatar
The black straps are available from Inline Tube. You will need a minimum of 3 straps. ILT sells on ebay here:
https://www.ebay.com/itm/397306194903
I’ve attached several pictures that are self explainatory with regards to the placement of the straps on the driver’s side. There are actually 3 clips involved on the driver side, the most discreet one is located where the positive battery cable curves around the valve cover at the firewall end of the engine and loops through the barrel insulator going to the starter, the remaining two clips are attached to bolt 2 and 3 of the driver side valve cover. On the passenger side there is one black strap attached to a clip held by a valve cover bolt as shown in diagram PIM Sec 8 pg 132.
Hope this helps.
Old Apr 17, 2026 | 07:06 PM
Jungle Cat's Avatar
Thank you. That helps a lot
Old Apr 18, 2026 | 05:03 AM
I'll concur that the square head plugs are correct, not the hex head.
Old Apr 18, 2026 | 08:05 AM
Jungle Cat's Avatar
Luckily I have a nice clean one
Old Apr 18, 2026 | 12:34 PM
I guess I learned something new today.
Old Apr 18, 2026 | 12:40 PM
tnswt's Avatar
It can happen to any of us—don’t sweat it.
Old Apr 18, 2026 | 01:01 PM
WTHIRTY1's Avatar
Escape From The Ordinary
Similar to the Muncie plug with the square head.
@tnswt Did your W-30 have headers at one point in its life?
Old Apr 18, 2026 | 02:37 PM
Jungle Cat's Avatar
Looks better now
Old Apr 18, 2026 | 02:39 PM
Jungle Cat's Avatar
Hurcules must have put that thing in there. Took some effort to get it out
Old Apr 19, 2026 | 07:50 AM
tnswt's Avatar
Jimmy, I can only assume so, as evidence of the casualty you noted. In my particular case, I made no replacement, but display the historical scar to bear witness as to how decisions made by past stewards of the car influence its condition today.
Old Apr 19, 2026 | 07:57 AM
WTHIRTY1's Avatar
Makes perfect sense to me. I am in the same boat with my red inners.
Warren Seale
Jan 19, 2025 11:27 AM
pnagy23
Apr 4, 2022 03:43 PM
doubleUthirty
Feb 9, 2019 11:45 AM
Rickman48
Apr 29, 2011 08:23 PM
firefrost gold
Mar 13, 2010 10:01 AM
