68 steering column
Old Jun 9, 2025 | 10:26 PM
servexcell's Avatar
68 steering column
is there anyone who has the knowledge of steering column that can offer me assistance on how to restore these
regards Bruce
Old Jun 10, 2025 | 07:05 AM
zl1 camaro's Avatar
What exactly are you trying to do.? Is this a tilt wheel ? Do you want to Replace the upper shaft bearing, install new switches, paint or all of the above...
Old Jun 10, 2025 | 07:43 AM
servexcell's Avatar
thanks for responding to my post. I am restoring a 68 Cutlass Convertible. i Just removed the original steering wheel 68 only i see there is a canceling cam and plunger for the horn maybe they should be replaced and i am checking to see for play in the bearings seems like there is a little maybe its normal . I will have it painted and install a sport steering wheel with simulated plastic woodgrain
Old Jun 10, 2025 | 08:42 AM
zl1 camaro's Avatar
Keep in mind the steering wheel needs to be installed & tight to ck for bearing play,that preloads the bearing ,Usually they don't go bad. There should be 2 turn signal cancelling springs. [left & right] or a plastic collar with arms for the left & right side,is this a tilt wheel & are you having any type of problems with this IF SO WHAT ????
IF the turn signals cancels & works ok & the horn works & there is no movement in the wheel & ignition switch is ok I would clean it & paint it and call it done.
Old Jun 10, 2025 | 09:57 AM
z11375ss's Avatar
Senior Moment Member
There are sooo many videos answering your questions they are too numerous to count. This is a great asset to have. Good luck! I searched Rebuilding GM A Body steering column on yootoob.
Roger60
Aug 22, 2024 07:42 AM
Gary's 2 442-S
Dec 29, 2021 12:41 PM
W-27
May 15, 2015 08:08 PM
68conv455
Nov 19, 2011 07:36 AM
sbFALL63
Feb 18, 2010 02:47 PM
