I bought this thinking it was a 404847 X pump. It has Almost the same dimensions. The outlet side is smaller
almost like it is for a 350 engine. They both have the cast impeller and are the same height. Anyone ever see one like this?
It shows to be made in the USA marked 5741.
Interesting. This pump may very well be a W-30 pump for a non a/c car. Didn't those have the smaller 3 core radiator?
If so, that would explain the smaller outlet for the 3 core. Hmmm... Thanks for the posts fasteddy.
That X pump with no casting number is a later built pump.
For some reason Olds stop doing things like that such as removing bleeders on later master's for instance.
It will have all the same dimensions,
The smaller outlet began in 1971.
Do you think it is an OEM pump that came on a car from the factory?
