1987 Cutlass Hood question
Old Aug 30, 2024 | 08:24 AM
69442murph's Avatar
I have a opputunity to purchase a 87 Cutlass hood that is NOS in the box.
Does this hood interchange with previous year models?
what would be the differences ?
This is not the Cutlass Ciera hood.
Thank you for any input.
tim
Old Aug 30, 2024 | 09:27 AM
69HO43's Avatar
What's the part number? If it's for a 4 door, that limits you to 4 door interchange. 4-door hood part number is 22515753 for steel version, 22515754 for aluminum version.
22515757 is the part number for a 2 door notchback G47 body style. This interchanges with A/G47 models from 81-88. It is steel. Technically incorrect for W40 models (Hurst/Olds) because the H/O hood (p/n 22521115) has 2 extra pieces of bracing underneath. But it will physically bolt on and fit.
There's also an aluminum version of that regular steel hood. p/n 22515758, but that's rare as hen's teeth. Plus you'd have to use the special hood hinge/springs and front pop up spring for the aluminum hood.
Old Sep 1, 2024 | 08:07 PM
69442murph's Avatar
Thank You.
Going to look at it this week. Thanks again!
Chris Scott
Aug 20, 2021 02:14 PM
72oldsman
Paint
Nov 1, 2019 06:53 PM
autcool
Mar 5, 2015 05:15 PM
MHENDERSON
Body work
Aug 26, 2013 06:04 PM
