1966 harmonic balancer
Old Feb 9, 2024 | 04:34 PM
Chuck22's Avatar
382356
know where I can buy a new harmonic dampener ? 1966 425. All I’m seeing from parts stores is a 1968 part that needs to be machined down. Any suggestions ? Are these not sold anymore?
Old Feb 9, 2024 | 05:40 PM
tru-blue 442's Avatar
Old School Olds
If you can find one from a 330, it will work too. I used one on my 66 400, it was fine.
Old Feb 9, 2024 | 05:42 PM
Have your original rebuilt.
Old Feb 10, 2024 | 05:02 AM
Chuck22's Avatar
good to know. But I’m afraid they are not produced anymore.
Old Feb 10, 2024 | 05:04 AM
Chuck22's Avatar
what type of shop should I be searching for? My machine shop doesn’t have a contact.
Old Feb 10, 2024 | 05:15 AM
66-3X2 442's Avatar
https://www.damperdoctor.com/
Old Feb 10, 2024 | 05:27 AM
Chuck22's Avatar
382356
Blue is a 455 for comparison. Some sites say to have a machine shop turn down the 455 . I’m guessing on a lathe take down some of the weighted item on the back?
Old Feb 10, 2024 | 08:30 AM
66-3X2 442's Avatar
The 425 balancer is internally balanced and the 455 is externally balanced. Just do it the right way and have a 425 rebuilt unless you can find a good used unit.
Old Feb 10, 2024 | 05:04 PM
Run to Rund's Avatar
Both are externally balanced engines, but there is less counter balance in a 330-early 400-425 balancer than in the later ones for the 350-late 400-455.
Old Feb 10, 2024 | 06:02 PM
66-3X2 442's Avatar
In other words they don't interchange. Tanks Dad for the info.
Old Feb 10, 2024 | 06:37 PM
Chuck22's Avatar
surprised there isn’t a unit with removable weights. Swap weights like a flywheel.
Old Feb 10, 2024 | 06:49 PM
66-3X2 442's Avatar
https://www.summitracing.com/parts/p.../442/year/1966
Old Feb 10, 2024 | 09:05 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Damper Dudes is another good place for a rebuild. I used them on the 54 I had and they did an excellent job.
Old Feb 11, 2024 | 04:42 AM
I am running an SFI-approved Pro-Race damper. which has a removable counter weight. It is sold for a 455. I had it re-balanced for my early 400 and am using the 455 timing tab because the mark on the damper is in a different place and the damper is a slightly different OD.
dragline
May 11, 2023 03:13 PM
MBOlds98
May 23, 2021 03:24 PM
rroth01
Dec 3, 2016 06:27 AM
Stevec
Aug 12, 2012 03:12 PM
martine
Apr 2, 2004 09:25 PM
