Neutral Balance Harmonic Balancer
Old May 13, 2021 | 08:29 AM
MBOlds98's Avatar
Hello everyone,
I'm currently working on a build for my 1966 Olds 425 engine. I have the block and rotating assembly at the shop now getting machined and balanced and we can hit neutral balance. I need to find a neutral balance harmonic balancer so if anyone has any knowledge or options let me know
Mike
Old May 13, 2021 | 08:40 AM
cutlassefi's Avatar
Scat 8022 or 9022. Both have removable weights.
Old May 13, 2021 | 09:34 AM
fleming442's Avatar
I have an ATI, but be careful because they're available with Ch*vy and Olds (4&3 bolt) pulley patterns.
Old May 13, 2021 | 03:17 PM
pettrix's Avatar
What about this balancer? It's SFI approved.
https://www.summitracing.com/parts/pfs-90022
Old May 13, 2021 | 03:50 PM
chadman's Avatar
ATI is the best you can buy. You can even get them with the magnets in the shell for a crank trigger.
Old May 13, 2021 | 05:36 PM
pettrix's Avatar
ATI is good but they run close to $500. While the Professional Products SFI approved one is $220.
Old May 13, 2021 | 05:45 PM
chadman's Avatar
You get what you pay for and you don't get what you don't pay for...
Old May 22, 2021 | 06:08 PM
wr1970's Avatar
There has been guys who have had problems with professional products sfi balancers. Now I am not mudding the waters I have used three no problems. But I also am not spinning past 6,000 RPM. I did buy a quality neutral balancer from TCI for my next build in the wings. Will I buy the PP balancer again no!!
Old May 22, 2021 | 06:58 PM
70W-32's Avatar
Everything Professional Products makes is a copy of some other companies product. They are reverse engineered parts made is Chinese shops who dont give a f**k if you motor self destructs, and you end up with a hole in you radiator or hood.
Hell, the intakes they made for Olds wouldnt even line up correctly, and needed machine work to be usable.
Old May 23, 2021 | 03:24 PM
pettrix's Avatar
Looks like ATI will be the better choice
Gene kerr
Apr 1, 2020 08:07 AM
griffey57
Feb 17, 2017 04:18 PM
71oldsS
Jun 4, 2015 05:50 PM
Stevec
Aug 12, 2012 03:12 PM
martine
Apr 2, 2004 09:25 PM
