Air cleaner top
Old Jan 31, 2024 | 03:12 AM
moetrizh's Avatar
Air cleaner top
Ram air air cleaner top
Hey guys is there a rubber gasket that goes in between the top plastic part and the base?
Because it wants to slide sides ways some time L
Old Jan 31, 2024 | 05:25 AM
VC455's Avatar
Barely Registered
There is a channel in the plastic top where it fits over the lip of the steel air cleaner housing. Aftermarket reproductions have a round-section gasket in the channel. The factory put a taller, square-section, rubber gasket in that channel.
Removing the gasket gains a bit of clearance to the hood. That may be what happened to yours.
Old Jan 31, 2024 | 09:49 AM
70Post's Avatar
The gasket is available from various repro parts suppliers. Made by SoffSeal (I think......need to double check).
The gasket is for the "standard" non-OAI air cleaner LID.....also works for the plastic flapper unit you're asking about.
Here's one that is the original square profile:
https://www.opgi.com/air-fuel-delive...xoC-NgQAvD_BwE
montvaleplace
Jun 9, 2019 08:33 PM
RROLDSX
Paint
Jun 23, 2014 07:35 PM
SavedbyHim
Feb 23, 2013 06:06 PM
67442HT
Jul 15, 2011 09:46 AM
marty
Hurst/Olds
Apr 18, 2009 08:00 AM
