Key stuck in ignition
Old Jun 17, 2023 | 08:26 PM
UncleOlds's Avatar
I have a 1970 442 and my key got stuck in the ignition today in the running position....can anyone help?
Old Jun 17, 2023 | 08:34 PM
Put it in park. Help convince it it is in park by grabbing the rotating collar, if it's a floor shifter, on the steering column and rotating left till it stops. Did it get stuck in the off position or the running position and you had to turn the engine off creatively?
Old Jun 17, 2023 | 08:41 PM
UncleOlds's Avatar
Yes. I had to disconnect the alternator and battery to shut it off. Everything shifting and running great. Just stuck key
Old Jun 17, 2023 | 08:45 PM
tkcutlass's Avatar
If it's a floor shifter make sure the backlink Is operating and adjusted correctly.
Old Jun 17, 2023 | 08:52 PM
UncleOlds's Avatar
where's the backlink?
Old Jun 17, 2023 | 09:01 PM
tkcutlass's Avatar
here's a post with a few pics https://classicoldsmobile.com/forums...estion-168395/
Old Jun 17, 2023 | 09:43 PM
tkcutlass's Avatar
There is also a rod going to the ignition switch that something may be interfering with it moving properly.
Did you try pushing the key and key collar in towards the column while turning it off?
Old Jun 18, 2023 | 06:17 AM
Is the backdrive linkage from the trans to the steering column in place? The collar on the steering column must be rotated fully counterclockwise for the key to rotate to the LOCK position.
Old Jun 18, 2023 | 09:07 AM
oldguy442's Avatar
Mine did the same thing a few weeks ago. I had to disassemble the steering wheel and pull the lock cylinder. Key would not turn in the cylinder. I wasn't worried about authenticity so Autozone had a new cylinder with key in stock.
Dave26
Mar 2, 2023 04:40 AM
oldsmike1972
Vista Cruiser & Wagons
Dec 14, 2021 08:45 AM
oldolds88
Dec 9, 2021 07:49 PM
firefrost gold
Hurst/Olds
Jul 8, 2018 12:19 AM
Garbled
Mar 24, 2015 10:46 AM
