1990 Cutlass intermittent dying while running
Old Apr 10, 2023 | 12:43 PM
Beemer's Avatar
Hello,
This car has a six cylinder motor, 34k and seems to be pretty solid. We have changed the oil and a few other things, usually runs great. However, a couple of times at stop lights it just dies, it will start back up after a try or two. It has done it a few times now and did it today while driving. It belongs to what I would call my "adopted son". Great kid saved for it himself, but isn't cash heavy. Any opinions as to what might be causing it? No CEL coming on. Thanks much
Old Apr 10, 2023 | 03:57 PM
fleming442's Avatar
If it has the double, sandwiched battery cables on the positive side, make sure the connections are clean and apply dielectric grease. I had an 89 Bonneville with the same problem, and that's what it was after a barrage of parts cannon ballistics.
Old Apr 11, 2023 | 04:51 AM
Beemer's Avatar
Hello,
I will check that. Thanks.
Old Apr 11, 2023 | 06:16 AM
You can have the ignition coils tested at your local auto parts store. Either on the car, or removed.
Old Apr 11, 2023 | 06:23 AM
Beemer's Avatar
Hello, Thanks. Do you think it could be a fuel filter?
Old Apr 11, 2023 | 06:51 AM
It could be fuel related. Next time it dies pop the hood and depress the schraeder valve on the fuel line near the fuel pressure regulator. It should squirt fuel. If it doesn't, move the key to OFF and then back to RUN. You should hear the fuel pump run. Then you should have pressure at the schraeder valve.
Old Apr 11, 2023 | 06:55 AM
Hammerdrop's Avatar
You need to start with a full code scan for sure.
Old Apr 11, 2023 | 07:06 AM
Beemer's Avatar
I am going to do the "paperclip" OBD1 code scan today. Is there a more complete method? Thanks!
Old Apr 20, 2023 | 07:48 PM
cjsdad's Avatar
Check the PCV valve. If it runs ok until you let it idle and then stalls, a bad PCV valve can introduce a massive air leak below the carb/throttle blade and starve the engine for fuel.
Old Apr 21, 2023 | 05:10 AM
Let us know what happens Beemer. He PM'd me and mentioned the car is getting coils and a tune up.
Old Apr 21, 2023 | 07:40 PM
1970greensupreme's Avatar
If you could get your hands on an old otc scanner you could get a limited data stream
Old Apr 24, 2023 | 05:42 AM
Beemer's Avatar
Hello, Yes we are doing the coils Tuesday. Thanks much.
Beemer's Avatar
I will check that as well.
bigmantinycar
Feb 25, 2026 08:56 AM
uawoody77
May 28, 2021 02:39 PM
piperman60
Mar 16, 2018 08:45 AM
ITS68
Aug 29, 2010 03:15 PM
69OldsCutlassS
Apr 30, 2009 02:49 PM
