TH350 or TH400
Old Jan 17, 2023 | 10:07 AM
Pantera928's Avatar
TH350 or TH400
In the 1970-72 Cutlasses with a 350, could the car have the option of a TH350 or a TH400? Seems like I have heard of both being available.
Old Jan 17, 2023 | 11:30 AM
I never heard of a Cutlass with a 350 engine having a TH400 from the factory.
Old Jan 17, 2023 | 12:14 PM
I believe the 68 Ram Rod was only offered in manual, and the later W-31s could have special TH-350s, JO, I think. This leads me to believe that one did not get a TH400 with a 350 Rocket.
Old Jan 17, 2023 | 02:05 PM
I have seen numerous unmolested station wagons with 400 transmissions and 350 engines.
Maybe that’s a station wagon thing?
Old Jan 17, 2023 | 02:43 PM
70W-32's Avatar
No T400 behind any 350ci motor, only 455 equipped cars got the T400 in 70-72
Old Jan 17, 2023 | 03:05 PM
You are correct. I checked the 72 specs book. May be true for other years.
Vista Cruisers and 88s could come with 350 engines sometimes of both 2 and 4 barrel variety and M40 TH 400.
Old Jan 18, 2023 | 06:06 AM
The flattop wagons came with the TH350 behind the SBO, period. The small block Vista and Delta 88 came with the TH375. This is a light-duty TH400 that used the TH400 case but fewer clutch plates in each drum and the smaller TH350-sized output shaft. The TH375 was only built in the long-tail version, which is why it was only used in the long-wheelbase cars like the Vista and B-body. The TH375 is easy to identify, as the tailhousing has 375THM cast right into it.
Old Jan 18, 2023 | 01:34 PM
The 69 station wagon I got my disc brake setup from was a 350 car, and had a 400 trans. A friend of mine parted out a 70 wagon also had a small block and 400 trans.
This was probably 20-25 years ago, long before wagons became desirable. At that time, they were parts cars. I have slept a lot since then, I don’t recall if they were cutlass wagons, or vista cruisers, or much about either of them other than they were both green.
Old Jan 18, 2023 | 05:52 PM
Well, like I said, the only "TH400" that was factory installed in an 1969 Olds wagon with a 350 motor was the long tail "OA" code TH375 in the Vista.
yeahbuddy
Jan 27, 2020 02:40 PM
70cutty
May 18, 2016 10:08 AM
Doomah
May 3, 2012 07:48 PM
wolfman98
Dec 10, 2011 10:08 AM
Omicron
Jul 16, 2007 08:39 AM
