Vent window question
Old Oct 16, 2022 | 06:21 PM
young olds's Avatar
On a 1967 cutlass is the vent window the same between a 4 door hardtop and a two door hardtop? I知 guessing post cars do not have the same vent window.
Old Oct 16, 2022 | 06:27 PM
Loaded68W34's Avatar
No, the angles of the windshield and A-pillar are different. On convertibles and 2 door hardtops the windshield is laid back. The 4 door hardtop shares the same winshield angle as the 2 door post, 4 door post, and wagon. Those have a windshield that stands up straighter.
Old Oct 16, 2022 | 06:46 PM
Here are some pics to help visualize:
This is a 67 4 door hardtop I bought to make a 66 chevelle 4 door hardtop wagon:
Here is a stock 66 A-body wagon roof line:
Here is a mock up of a 66/67 2 door hardtop roof line on my 66 chevelle 2 door hardtop wagon project. Notice how different the angles are. Originally, I planned to use the 66/67 roof line, but decided even after all the work of changing the front roof area, the C-pillar would never look right. So, I decided to use a 64/65 hardtop roof line and glass instead.
The windshield angle was the same across all 65 body styles so the angles were not a problem.
This might be more info than you needed, but the simple answer is no. 2 door hardtop and 4 door hardtop are not the same. Both due to the windshield angle and the fact that that the 4 door hardtop wing window does not go as far back along the door.
Old Oct 16, 2022 | 07:20 PM
young olds's Avatar
To be clear I can use a vent window from any 67(66 as well?) other then 2 door hardtop and convert in a 4 door hardtop?
Old Oct 17, 2022 | 04:40 AM
No, despite using the same windshield angle as the post bodies, The 4 door hardtop wing window shape is unique to 66/67 4 door hardtop. If you look at the first two pics in the post above, you can see how the 4 door hardtop cutlass and 4 door wagon have totally different shaped windows. Are you missing a window in your car, or simply trying to get nicer chrome/ glass to replace what you have?
Old Oct 17, 2022 | 06:15 AM
young olds's Avatar
I am missing the glass and latch.
Old Oct 17, 2022 | 07:37 AM
Which side? Green tint or clear? I have a few sets from cars I have parted out. I would be willing to let go of one of my clear pieces. Shipping should not be too bad if it is just the glass and not the whole assembly.
Old Oct 17, 2022 | 10:08 AM
young olds's Avatar
My car has clear glass and just the glass will be fine, thanks for the offer I’ll pm you.
Old Nov 12, 2022 | 08:57 PM
young olds's Avatar
I got the vent glass I needed. Now I’m curious if the windshield is shared with any other models or if it has to be 4 door hardtop specific like the wing window?
Carsick
Aug 27, 2022 12:38 PM
Dave痴 Holiday 55
May 25, 2022 01:57 PM
7314haywood
Jun 21, 2021 09:11 AM
airborne1942
May 18, 2015 05:15 PM
StarGeneral
Body work
Jan 25, 2012 10:58 AM
