1967 cutlass dash insert removal
Old Sep 15, 2022 | 02:19 PM
KcPaul's Avatar
Hello everyone. I have a 1967 cutlass, thinking about buying the plastic dash insert. Can someone tell me if I have to remove the dash pad to take the insert out? Has anyone bought an after market insert? I was just wondering about the quality of the silver finish it has. And the fitment. does anyone have experience with the after market dash pad? I heard the dash pad itself has a fitment issue. I havent heard anything about the dash insert fitment. Im thinking of buying one from The Parts Place inc
Old Sep 15, 2022 | 06:34 PM
Oldsmaniac's Avatar
I have one from the parts place, tried it in a spare dash pad and fit was good with no issue. I did not install it yet but swapped the speedo, and fuel gage into it along with the circuit board. No real issues but I did open up same holes as the self threading screws seemed a bit tight and did not want to risk splitting the new dash. The instrument panel itself seems to be able to install without removing the dash pad but yes this job will be time consuming.
Old Sep 15, 2022 | 09:25 PM
KcPaul's Avatar
OK thanks for your input. I figured it would be time consuming but it doesnt look to hard to do. Plus the new dash insert looks awesome
Old Sep 16, 2022 | 04:23 AM
fleming442's Avatar
The pad needs to come out to change the whole piece, but the speedo/tach/fuel pod comes out on its own.
Old Sep 16, 2022 | 08:13 AM
67OAI's Avatar
Old(s)GuysRule
KcPaul, there is a good pictorial of the dash removal from a 66/67 in the "stickies" above. It may help.
Old Sep 16, 2022 | 12:09 PM
Rocketguy's Avatar
The easiest way to pull these is with the wire harness intact. Disconnect the HVAC control cables, remove the fuse block from the firewall and remove it all at one time.
Also remember that the '66 and '67 IP inserts are different.
Old Sep 16, 2022 | 01:31 PM
66-3X2 442's Avatar
All of that work repo'ing the dash bezel and they didn't get it right. TPP is notorious for that. Not knocking you oldsmaniac,not your fault.
Old Sep 16, 2022 | 06:52 PM
68442's Avatar
What didn't they get right?
Old Sep 16, 2022 | 06:54 PM
66-3X2 442's Avatar
The lettering around the switches and gas gauge opening are supposed to be chrome,not painted
Old Sep 17, 2022 | 04:03 AM
35tac's Avatar
Nice catch. Who would have thought.
Wayne
Old Sep 17, 2022 | 04:42 AM
Oldsmaniac's Avatar
The lettering around the switches and gas gauge opening are supposed to be chrome, not painted
Hard to see in the picture but the letters are not painted silver like the rest of the dash. They are chrome or possibly chrome painted. The only possible deviation could possibly be that the vertical speaker bars ARE just silver paint, not sure if they should be chrome. For my car this dash is very acceptable and a GREAT improvement over what is there and a thousand dollar saving over what a restored on would cost.
Old Sep 17, 2022 | 05:04 AM
68442's Avatar
I'd be willing to bet the speaker grill area is chrome under the paint. The whole piece was probably chromed then painted/detailed .Maybe a cue tip with lacquer thinner ????
On that subject does anyone know for sure how much of the grill is chrome ? The few i have are so worn it is tough to tell.
Old Sep 17, 2022 | 06:49 AM
66-3X2 442's Avatar
That's better,looked painted in the original picture.
Oldscutlass67
Mar 17, 2019 04:01 PM
rickbmac
Jul 16, 2016 04:27 AM
fv64olds98
Jun 14, 2013 10:55 PM
Redog
Jun 25, 2011 10:17 PM
higear
Oct 22, 2008 02:37 PM
