Notched Rocker Arm Valve Cover odditty
Old May 28, 2022 | 12:58 PM
11971four4two's Avatar
MOTORHEAD
I have not seen one of these before.
Has notch corner
Raised area areola around the breather hole
The center of the top is trough indented
I guess hang it on the wall
Old May 28, 2022 | 01:42 PM
dbater's Avatar
1967 442 with power brakes???
Old May 28, 2022 | 01:51 PM
MOTORHEAD
That is originally what I thought??
But that is the opposite side as this should be on
ONLY TO CONFUSE
Here are pictures of a 1967 442 notch For Reference
Old May 28, 2022 | 02:07 PM
dbater's Avatar
How about with A/C?
Old May 28, 2022 | 02:33 PM
MOTORHEAD
How about with A/C?
I suppose they nay do that
B
Old May 28, 2022 | 02:47 PM
The 1967 cars only used a notched valve cover on the driver side, and it was the same notched cover as used on the 68-72 cars since it was designed to clear the same 11" booster (64-66 cars used a 9" booster and did not need the notch). The 64-67 HVAC box is different from the 68-72 cars and does not require the notch. I've never seen one like this either. Could be mal-formed?
Old May 28, 2022 | 02:53 PM
MOTORHEAD
Really
Fooled the Geezerl
Old May 29, 2022 | 07:42 AM
67OAI's Avatar
Old(s)GuysRule
You mention the top being "indented" as in a trough; I think that was only in 1965.
Old May 29, 2022 | 08:20 AM
1964 and 65
Old May 29, 2022 | 08:25 AM
rocketraider's Avatar
Oldsdruid
The parts book is no help. Maybe Climatic Combustion Control? Those units had a lot of weird pieces.
Old May 29, 2022 | 08:37 AM
The valve cover in question is definitely 1964-65. The round "areola" around the breather hole (yes, I'll be using that from now on... ) is unique to those years. The 66-72 valve covers are flat across the top. The 73-90 covers use a raised area around the breather but it is D-shaped, not round.
Old May 29, 2022 | 09:12 AM
dbater's Avatar
Perhaps the 1965 425 used for irrigation or stationary power??
Old May 29, 2022 | 09:14 AM
But why would it need a notch? There's nothing to clear.
Old May 29, 2022 | 09:20 AM
dbater's Avatar
IDK never seen one but a lot of self contained powerplants have a lot of framework around them for various reasons, air intakes, heat exchangers etc.it is weird!
70Post
Aug 30, 2020 02:16 PM
dre
May 14, 2020 04:16 AM
Matt Joseph
Mar 26, 2019 03:47 PM
michaelscott
Nov 25, 2012 08:13 PM
antweave
Aug 25, 2011 02:27 PM
