64 olds dynamic 88 brake drum specs
Old April 27th, 2022, 02:51 PM
hundayguy's Avatar
Hello, I am looking for Front and rear brake drum diameter and service limit. Any help will be appreciated.
hundayguy is offline
Old April 27th, 2022, 03:17 PM
Nominal is 11.00 x 2.50 on the front and 11.00 x 2.00 on the back. The service limit should be cast or stamped onto the face of the drum, typically near the edge, but the discard limit is 11.090"
joe_padavano is offline
Old April 27th, 2022, 06:13 PM
hundayguy's Avatar
Thank you Sir. I appreciate the quick reply. You seem to be very knowledgeable about these old rides. I appreciate you knowledge and willingness to share it.
regards, Javier
Old April 27th, 2022, 06:19 PM
Phantom Phixer
Charlie Jones's Avatar
There was no service limit stamped or cast on these brake drums.
I don't think that practice started until the late sixties.
However, you are correct that 11.090 is considered the maximum size for serviceable drums.
Charlie Jones is offline
Bigbassape
June 15th, 2021 06:47 AM
stephenca118
December 15th, 2020 10:56 AM
Nikojoe
Brakes/Hydraulic Systems
23
April 13th, 2020 08:30 PM
johns72olds
July 5th, 2016 01:01 PM
eodette
October 12th, 2010 07:26 PM
Quick Reply: 64 olds dynamic 88 brake drum specs
