Alternator Bracket/ Brace
Old Mar 31, 2022 | 06:57 PM
tkcutlass's Avatar
I don't recall taking off the rear brace (398887) for the alternator is it possible it was running without it?
It looks like the alternator will mount fine without it.
Old Apr 1, 2022 | 05:40 AM
The car will run if you leave off the air cleaner also...
Look, GM did not put unnecessary parts on these cars just to reduce profit. The brace is there because without it there is deflection of the alternator towards the water pump due to belt tension. This causes fatigue that will eventually cause cracks in the remaining bracket. There was one there when the car left the factory.
Old May 4, 2022 | 08:07 AM
oletrux's Avatar
What year is that bracket off of?
Where does the brace attach to the engine?
What engine??
I'm having an alignment issue with bolting up to aluminum heads........
Old May 4, 2022 | 08:24 AM
edzolz's Avatar
Since Oldsmobile did not offer aluminum heads as a factory option, there probably will not be a factory brace that will bolt up. A good fabricator will be able to make a brace for you that will look and function like factory.
Old May 4, 2022 | 10:19 AM
oletrux's Avatar
That style of bracket looks like it will work. Have you got one?
I'm the fabricator.....so I get to engineer and manufacture the brace, but I need the alternator in place first to do that.!
Thanks.
Old May 4, 2022 | 09:28 PM
What engine??
I would think a little time spent with a grinder would provide the clearance needed. The other option is to swap to the later year brackets. That’s what I’m using on my car, they fit and function just fine.
Old Jul 1, 2022 | 01:30 PM
olds80six's Avatar
Old Jul 1, 2022 | 01:31 PM
olds80six's Avatar
TicTocTach
Jul 22, 2018 05:36 PM
jakedog3wfwf
Apr 12, 2018 05:30 PM
Chumpy2112
Apr 30, 2015 09:14 AM
Nasty455
Sep 14, 2012 07:16 PM
aristellier
Jul 23, 2012 10:01 AM
