Tips on a 68 442
Old Mar 25, 2022 | 09:01 PM
tkcutlass's Avatar
Tips on a 68 442
I may be traveling to look at a 68 442 tomorrow, any tips price range, etc
Old Mar 25, 2022 | 09:23 PM
It's all about condition and rust issues. With your limited info it's a very large swing in price.
Old Mar 25, 2022 | 09:38 PM
tkcutlass's Avatar
68 442 4 speed, mainly original paint. needs interior runs, drives, minimal rust based on pics
Old Mar 26, 2022 | 03:23 AM
allyolds68's Avatar
with no pics and not much other info, $10-$25k in todays market.
Unless you live in the desert southwest, there really isn’t any such thing as “minimal rust”. It’s always 10x worse than you think it it
Old Mar 26, 2022 | 03:59 AM
deadeyejedi's Avatar
If you do end up going Tim let me know how it works out.
Old Mar 26, 2022 | 05:15 AM
Eddie Hansen's Avatar
Fingers crossed
Fingers crossed it’s everything you hope it is ! Obviously I love the 68-69 cars and a four speed? So cool good luck brother
Old Mar 26, 2022 | 07:07 AM
It's nearly impossible for a car in the rust belt (ie, CT) to have "minimal rust". Look for half-fast repairs. Pay very, very close attention to rust under the glass at the base of the windshield and back window, as well as all around both pieces of glass under the stainless trim. The pinchweld rust is unfortunately insidious on these cars.
Old Mar 26, 2022 | 09:46 AM
tkcutlass's Avatar
Here's the "Hurst Olds" I just looked at
https://newlondon.craigslist.org/cto...457399358.html
Price was firm, Might be worth 25K to someone, Canada car.
Rust not terrible hood needed adjust or had bent hinges.
Exhaust leak.
Good vinyl top replaced approx 15 years.
Old Mar 26, 2022 | 10:52 AM
tkcutlass's Avatar
Here are a few pics I took while there
Old Mar 26, 2022 | 11:19 AM
BackInTheGame's Avatar
In it's present condition I might go $12.5, no more. It is a rust bucket, through and through. But I like the color - same as the original on my first Cutlass S. I paid $14.5 for my current '68 4-speed 4-4-2 in much better shape with AC, power windows, console. Admittedly that $14.5 was 12 years ago, but still.. in today's market I think mine would be worth about $25- to maybe $30 on the top end to the "right buyer." And it's been refreshed mechanically and aesthetically, with very little rust.
Just my $.02. YMMV
Old Mar 26, 2022 | 11:50 AM
Umm ... how is that a Hurst/Olds?
Old Mar 26, 2022 | 11:53 AM
You might want to ask the seller, who clearly doesn't know that every MT 442 in 1968 came with a Hurst shifter. There's a reason why the post says "Hurst/Olds" in quotes.
Old Mar 26, 2022 | 12:52 PM
tkcutlass's Avatar
Upon leaving the seller got a little upppity when I tried to explain that his car wasn't a Hurst Olds.
And I question the 4.11 gears, from my research, 4.11 gears was dealer installed only. "And it must be a 12 bolt rear cuz it has 12 bolts on the cover"
I told him it might be worth getting the info on his Canadian car. He had the car since 75 and is the second owner, Never driven in the snow garaged since he's had it.
Old Mar 26, 2022 | 01:09 PM
Yes, it might be very interesting to get the VVS package and find out how the car left the factory.
Old Mar 26, 2022 | 01:12 PM
4.11 gears were not an option for the Type O axle. 4.33, or 4.66 were the only ratios in the fours. By the way, if it's an Oshawa car (as opposed to US-built), it did come from the factory with a Chevy 12 bolt.
Old Mar 26, 2022 | 01:38 PM
tkcutlass's Avatar
Yes, I believe it is. but thought I saw something about 4.11 being only a dealer-installed option.
Old Mar 26, 2022 | 01:42 PM
Perhaps for Oshawa cars. The only "dealer installed" ratio options shown for US cars are 4.33, 4.66, and 5.00. Certainly 4.11 gears exist for the Chevy 12-bolt, and certainly someone could have paid a dealer to install them. They were not shown in any of the Olds literature or parts books, however. 3.31 is the steepest ratio available through the Olds parts network. Obviously a Chevy dealer could get 4.11s.
Old Mar 26, 2022 | 02:10 PM
I remember reading somewhere the Canadian cars got the Chevy 12 bolt instead of the O axle?
Old Mar 26, 2022 | 03:32 PM
CANADIANOLDS's Avatar
That things looks solid and original. Says original numbers matching block.
why is anyone guessing if it’s a Canadian car. It’s right there in the pics. So it should have the 12 bolt chev if its original rear.
Old Mar 26, 2022 | 03:42 PM
Speaking of hidden rust. This picture scares me ..
Moisture along the windshield channel from the inside is never a good sign.
Old Mar 26, 2022 | 04:39 PM
you scare easily
Old Mar 26, 2022 | 04:41 PM
you scare easily
To be honest from the photo I can't tell if that's rust, moisture, or just delamination in the glass.
Old Mar 26, 2022 | 05:13 PM
Loaded68W34's Avatar
I actually thought it was bugs and dust that had gathered in that area over the past 50 plus years. It is a pretty hard area to clean without an air compressor and a blow gun.
Old Mar 26, 2022 | 05:19 PM
Blown up veiw, pretty sure it is just dust, and debris.
Old Mar 26, 2022 | 05:25 PM
Think that was already covered. Yes, Chevy 12-bolt in '68-9, IIRC standard ratio was 3.07.
Old Mar 26, 2022 | 05:34 PM
Yellowstatue's Avatar
It is very possible that that car could have an Olds axle. 3:42 or 3:91. Not all Oshawa cars left the factory with Chebby axles. Someone is trying to create a myth.
Old Mar 26, 2022 | 05:58 PM
Joe P. would never do that!
Old Mar 26, 2022 | 06:33 PM
So long as it is inspected by the buyer than all is good.
Candianolds bite me.
Old Mar 26, 2022 | 07:45 PM
allyolds68's Avatar
3.07 wouldn’t have been available on an M21. I don’t have my assembly manual handy but in 68 the lowest number gear ratio you could get with an M21 was 3.42. (That was also the highest you could get with an M20).
Old Mar 27, 2022 | 07:14 AM
You're right -- I forgot it was a four-speed.
Old Mar 27, 2022 | 11:51 AM
  #31
My wife's car with M21 has a 3:91...documented. Mine, with M20 has a 3:42...documented.
Old Mar 27, 2022 | 11:54 AM
  #32
Both of which are shown to be available in the page from the SPECS booklet I posted above.
Old Mar 27, 2022 | 04:06 PM
  #33
it’s possible to have that but not possible to be assembled from GM that way on a Canadian built car
every Olds A body made in Oshawa in 68/69 did come with a 12 bolt chev.
I’ve had many of them over the years and still have some Oshawa A body’s. A 68 442, a 69 442, a 69 F85 6cyl car All 12 bolt chevs
The reason GM did this was because the Drive train assembly plant for GM was in St Catharines just 1 hr and 45min down the road where 12 chev diff was made..
Old Mar 27, 2022 | 05:44 PM
  #34
I missed that in Joes first comment.
Old Mar 28, 2022 | 05:47 AM
  #35
allyolds68's Avatar
This is the Oshawa rear end availability out of the PIM
The 442's are only circled as I previously posted this somewhere else
Old Mar 28, 2022 | 09:50 AM
  #36
I feel like paying myself for the VVS Canadian docs on this car
Old Mar 29, 2022 | 04:57 AM
  #37
Crimson@69442's Avatar
This may provide some info for your original question what to pay! I paid 25k for this car over a year ago, 59k miles one family owed out of bay area in Ca. Car is a power window, power seat A/C car. Interior, carpet/seats needed redone, paint heavy oxidized I have since buffed out but will need painted eventually, Overall a solid, numbers matching car. It will be kept bone stock, it is a drum brake car with 3:23 non posi rear. Some unforseen things I have learned, all power windows/seat needed rebuilt at 50 years old the were not working. I found an OCA member in florida who rebuilt them and they work great. This was $1,300. I would not buy a power window car again unless they are already rebuilt. These are a nightmare to line up. Still can't get the rear drivers lined up so it doesn't hit the 1/4 on the way up. The track may be bent.
Old Mar 29, 2022 | 06:52 AM
  #38
Nice score, Crimson, especially for a convertible! Regarding the windows, there is a process described in the Fisher Body Service manual for installing and adjusting the tracks and glass. It is a big help to use the "witness marks" of where all the bolts/nuts were located before taking them apart.
oldcutlass
Oct 21, 2017 03:43 AM
Olds Key Man
Mar 18, 2012 03:17 PM
ctrain22
Jul 20, 2010 03:11 AM
DR_DAN
Aug 22, 2006 02:14 PM
