May ha figured out why top end has been lacking
Old Sep 20, 2021 | 09:14 PM
Donaldbabineau's Avatar
I have been watching Vice Grip Garage on YouTube. I wouldn't follow most of what he does, but he uses a lot of fuel filters crippling old cars home. I noticed he used the inline filter I have on my car, but cutting the small ends. I put a larger filter on. Can't test it yet until I straitened out some other issues. May also explain why I seems I have been running lean.
Old Sep 20, 2021 | 10:04 PM
Don’t know if you are aware, but the filter on the right is available with different size hose nipples. Use the larger 5/16” or 3/8” for auto engines; I use 3/8” on my car.
Old Sep 21, 2021 | 12:20 PM
bigrbandit's Avatar
72 Cutlass Ponca City OK
Also, the filter on the left is a copy of the Bosch unit originally for VW beetles. Perfect for a continuous 40HP. x2 on 3/8 filter minimum. And if you are using an external filter, you should be OK to remove the tiny pleated or sintered filter inside the Qjet.
Old Sep 21, 2021 | 02:09 PM
fleming442's Avatar
AND, plastic melts and glass breaks. I like metal around my flammables.
hastingsman
Jul 25, 2020 04:37 AM
Gone Johnson
May 3, 2018 09:26 AM
jpc647
Nov 2, 2014 03:40 PM
BStone
Aug 13, 2011 06:16 AM
RussTad
May 28, 2008 03:16 PM
